11 Replies Latest reply on Jan 12, 2016 10:38 AM by resdesign
    Play all stage labels dynamically without knowing name or time
    JerryJackson Level 1
      Hello,
      I'm working on creating a "coverall" code snippet that can dynamically pull label names and locations from the default stage timeline to use in a Back/Forward button pair.  I can see this information in the _edge javascript file, but my coding skill is not sufficient to pull this information into a usable array.
      I am comfortable using getPosition and getLabelPosition.
      I have found snippets that used to work but work no longer, such as:
      var stage = sym.getComposition().getStage();
      var labels = stage.timelines['Default Timeline'].labels;
      I then used jquery's $.each command to look through, but I was unable to make it work.
      Thanks in advance for any help you can provide!
