7 Replies Latest reply on Jan 19, 2016 11:10 AM by Henrysam79cu
    As concatenate text from multiple checkbox
    Henrysam79cu
      selections: example:
      1-checkbox: The car is
      2-checkbox: my property
      3-checkbox: rented
      The results could be:
      The car is my property
      The car is rented
      etc.
        • 1. Re: As concatenate text from multiple checkbox
          You can use this script as the custom calculation script of the first field:
          event.value = this.getField("1-checkbox").value + " " + this.getField("2-checkbox").value;
          And this code for the second field:
          event.value = this.getField("1-checkbox").value + " " + this.getField("3-checkbox").value;
          • 2. Re: As concatenate text from multiple checkbox
            Henrysam79cu Level 1
            Thanks for the answer, but what I really need is.
            Whenever you mark a check box displays the contents and then check all the boxes that go jogging.
            say we have 20 checkboxes and select 9 or 16, it should show only the text of the check box activated.
            Thank you for your help
            • 3. Re: As concatenate text from multiple checkbox
              So where is this text coming from? Is there a matching text field for each check-box, or do you want to hard code into the script?
              • 4. Re: As concatenate text from multiple checkbox
                That is a little different from what you first described. It is also more complex. You showed an example with 3 check boxes but your example only had 2 of 3 items at a time selected. It might happen that 3 items could be selected but it would not be physically logical.
                You heed to setup your check boxes so the "Selected: value is the text you want to populate the text field.
                You may also need some controls to make sure lead-in statement like "The car is " is selected before either of the check boxes in the group "Ownership" is selected.
                I feel you have not clearly explained you requirements for the script.
                • 5. Re: As concatenate text from multiple checkbox
                  I need say is that whenever SELECTIONS check this box to display a text.
                  if the selection is several check boxes for the texts to be displayed consecutively in any order.
                  forgiving translation
                  • 6. Re: As concatenate text from multiple checkbox
                    I would create a document level funtion to concatenate upto 3 fields at time and not include and values that have a null string. It would also support the ability to insert an options seperator characater if supplied and and not use a null string as the seperator.
                    A possible script:
                    // Concatenate 3 strings with separators where needed
                    function fillin(s1, s2, s3, sep) {
                    Purpose: concatenate up to 3 strings with an optional separator
                    inputs:
                    s1: required input string text or empty string
                    s2: required input string text or empty string
                    s3: required input string text or empty string
                    sep: optional separator sting
                    returns:
                    sResult concatenated string
                    // variable to determine how to concatenate the strings
                      var test = 0; // all strings null
                      var sResult; // re slut string to return
                    // force any number string to a character string for input variables
                      s1 = s1.toString();
                      s2 = s2.toString();
                      s3 = s3.toString();
                      if(sep.toString() == undefined) sep = ''; // if sep is undefined force to null
                    assign a binary value for each string present
                    so the computed value of the strings will indicate which strings are present
                    when converted to a binary value
                      if (s1 != "") test += 1; // string 1 present add binary value: 001
                      if (s2 != "") test += 2; // string 2 present add binary value: 010
                      if (s3 != "") test += 4; // string 3 present add binary value: 100
                      /* return appropriate string combination based on
                      calculated test value as a binary value
                      switch (test.toString(2)) {
                      case "0": // no non-empty strings passed - binary 0
                         sResult = "";
                      break;
                      case "1": // only string 1 present - binary 1
                         sResult = s1;
                      break;
                      case "10": // only string 2 present - binary 10
                         sResult = s2;
                      break;
                      case "11": // string 1 and 2 present - binary 10 + 1
                         sResult = s1 + sep + s2;
                      break;
                      case "100": // only string 3 present - binary 100
                         sResult = s3;
                      break;
                      case "101": // string 1 and 3 - binary 100 + 001
                         sResult = s1 + sep + s3;
                      break;
                      case "110": // string 2 and 3 - binary 100 + 010
                         sResult = s2 + sep + s3;
                      break;
                      case "111": // all 3 strings  - binary 100 + 010 + 001
                         sResult = s1 + sep + s2 + sep + s3;
                      break;
                      default: // any missed combinations
                         sResult = "";
                      break;
                    return sResult;
                    Note that binary values are used to determine which combination of the 3 possible strings for concatenation is used to provide the result.
                    A possible custom calculation script for the text field could be:
                    var aFields = new Array("Check Box1", "Check Box2", "Check Box3");
                    var aValues = new Array();
                    for(var i = 0; i < aFields.length; i++) {
                    aValues[i] = this.getField(aFields[i]).value;
                    if(aValues[i] == "Off") aValues[i] = "";
                    } // process next field;
                    // clear result;
                    event.value = "";
                    // create concatenated value from the value of the fields;
                    for(var i = 0; i < aValues.length; i++) {
                    event.value = fillin(event.value, aValues[i], "", " ");
                    So with your example, checking all three results in:'
                    The car is my property is rented
                    It makes no practical sense since owning and renting are mutually exclusive.
                    • 7. Re: As concatenate text from multiple checkbox
                      Thanks for you help
