6 Replies Latest reply on Jan 9, 2016 9:16 AM by kglad
    How to add two datagrid controls on same form? I am getting error ..
    FlashLearner
      I need to add two datagrid controls on same page. When I try to drag another datagrid control from Components window, it says "A component with this name already exists in Library".
      How can I add more datagrid controls on same page?
      Regards.
        • 1. Re: How to add two datagrid controls on same form? I am getting error ..
          drag the control grid from your library to your stage.  you don't need (and can't add) another from the component panel.
          • 2. Re: How to add two datagrid controls on same form? I am getting error ..
            FlashLearner Level 1
            Thanks. Now the error is as following:
            **Warning** The linkage identifier 'fl.controls.DataGrid' was already assigned to the symbol 'DataGrid', and cannot be assigned to the symbol 'DataGrid2', since linkage identifiers must be unique.
            I am using the following actionscript3 code:
            import fl.data.DataProvider;
            import fl.controls.dataGridClasses.DataGridColumn;
            import flash.events.Event;
            import flash.net.URLRequest;
            import fl.events.ListEvent;
            var COL_SLNO:DataGridColumn = new DataGridColumn("S. No.");
            myGrid.addColumn(COL_SLNO);
            COL_SLNO.width=15
            var COL_DESCRIPTION:DataGridColumn = new DataGridColumn("Description");
            myGrid.addColumn(COL_DESCRIPTION);
            COL_DESCRIPTION.width=80
            var COL_PATH:DataGridColumn = new DataGridColumn("FILE_LOCATION");
            myGrid.addColumn(COL_PATH);
            COL_PATH.sortOptions = Array.NUMERIC;
            COL_PATH.width=1
            var allDatabase:Array = [];// contains all users like in xml
            var currentDatabase:Array = [];// contains users that need to be displayed
            var _loader:URLLoader = new URLLoader();
            var _data:XML = new XML();
            _loader.addEventListener(Event.COMPLETE, readXML);
            _loader.load(new URLRequest("Docs/Schedule/Agri/ScheduleAgri.xml"));
            function readXML(event:Event):void
            _data = new XML(event.target.data);
            for each (var usr in _data.user)
            allDatabase.push({id: usr.@id, SLNO: usr.@SLNO, DESCRIPTION: usr.@DESCRIPTION, PATH: usr.@PATH});
            currentDatabase = allDatabase.concat();
            updateList();
            function updateList():void
            myGrid.dataProvider = new DataProvider ();
            for (var i:int = 0; i<currentDatabase.length; i++)
            myGrid.addItem({"S. No.": currentDatabase[i].SLNO, "Description": currentDatabase[i].DESCRIPTION, FILE_LOCATION: currentDatabase[i].PATH});
            //myGrid.addEventListener(Event:ListEvent.ITEM_CLICK, gridItemClick);
            myGrid.addEventListener(ListEvent.ITEM_CLICK , gridItemClick);
            function gridItemClick (e:ListEvent):void
            var urlR:URLRequest=new URLRequest(e.target.getItemAt(e.rowIndex).FILE_LOCATION)
                navigateToURL(urlR, "_blank");
            • 3. Re: How to add two datagrid controls on same form? I am getting error ..
              Now, I change the code for the second datagrid as below:
              var COL_SLNO2:DataGridColumn = new DataGridColumn("S. No.");
              myGrid2.addColumn(COL_SLNO2);
              COL_SLNO2.width=15
              var COL_DESCRIPTION2:DataGridColumn = new DataGridColumn("Description");
              myGrid2.addColumn(COL_DESCRIPTION2);
              COL_DESCRIPTION2.width=80
              var COL_PATH2:DataGridColumn = new DataGridColumn("FILE_LOCATION");
              myGrid2.addColumn(COL_PATH2);
              COL_PATH2.sortOptions = Array.NUMERIC;
              COL_PATH2.width=1
              var allDatabase2:Array = [];// contains all users like in xml
              var currentDatabase2:Array = [];// contains users that need to be displayed
              var _loader2:URLLoader = new URLLoader();
              var _data2:XML = new XML();
              _loader2.addEventListener(Event.COMPLETE, readXML2);
              _loader2.load(new URLRequest("Docs/Schedule/Petro/SchedulePetro.xml"));
              function readXML2(event:Event):void
              _data2 = new XML(event.target.data2);
              for each (var usr2 in _data2.user2)
              allDatabase2.push({id: usr2.@id, SLNO: usr2.@SLNO, DESCRIPTION: usr2.@DESCRIPTION, PATH: usr2.@PATH});
              currentDatabase2 = allDatabase2.concat();
              updateList2();
              function updateList2():void
              myGrid2.dataProvider = new DataProvider ();
              for (var i:int = 0; i<currentDatabase2.length; i++)
              myGrid2.addItem({"S. No.": currentDatabase2[i].SLNO, "Description": currentDatabase2[i].DESCRIPTION, FILE_LOCATION: currentDatabase2[i].PATH});
              //myGrid2.addEventListener(Event:ListEvent.ITEM_CLICK, gridItemClick);
              myGrid2.addEventListener(ListEvent.ITEM_CLICK , gridItemClick2);
              function gridItemClick2 (e:ListEvent):void
              var urlR2:URLRequest=new URLRequest(e.target.getItemAt(e.rowIndex).FILE_LOCATION)
                  navigateToURL(urlR2, "_blank");
              First datagrid is woking fine but the second one gives the following error:
              ReferenceError: Error #1069: Property data2 not found on flash.net.URLLoader and there is no default value.
                at Schedule_fla::Messages_1/readXML2()
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at flash.net::URLLoader/onComplete()
              • 4. Re: How to add two datagrid controls on same form? I am getting error ..
                should be
                _data2 = new XML(event.target.data);
                (actually, it's better if it were
                _data2 = XML(event.target.data);
