10 Replies Latest reply on Jan 9, 2016 9:08 AM by A.T. Romano
    Adobe 14 Premiere shake reduction hangs on ?
    gilbertoj97886933
      Tried applying "Shake Reduction" to a 2 minutes clip, Quick Mode. It was finished successfully in about 12 minutes.
      However, when using the "No Motion" shake reduction option for the same clip, it takes about 6-7 minutes to analyse the clip and afterwards it hangs up with the message "Shake Reduction in progress".
      Also,  a window "Save Project" shows up but also this is hanging up at 5%.
      If I split the same clip and use a 12 seconds segment duration for example, the Shake Operation with No Motion yes did go through.
      When using the No Motion option is there any limitation on the clip length ?
