6 Replies Latest reply on May 15, 2006 8:02 AM by Newsgroup_User
    rounded corners
    mattyman0 Level 1
      I have a rectangle I made with the rectangle tool. If I slice the rectangle using the slice tool the option for the corner roundness goes away. Is there any way around this?
      Thank You
        • 1. Re: rounded corners
          Level 7
          Apply the roundness before you slice?
          Peter
          ____________________
          "mattyman0" <webforumsuser@macromedia.com> wrote in message
          news:e48ji4$d59$1@forums.macromedia.com...
          | Thank You
          • 2. Re: rounded corners
            mattyman0 Level 1
            I'm sorry. I meant knife tool not slice tool
            • 3. Re: rounded corners
              Level 7
              news:e49pop$ram$1@forums.macromedia.com...
              No problem, that's what I thought you meant.
              I created a rectangle, applied a roundness of 25 and then cut it in half
              with the knife without loosing any of the roundness.
              Peter
              • 4. Re: rounded corners
                senocular
                You're not going to be able to retain the roundness option after cutting it, though. That is solely for rectngle shapes.
                What you could do (Fireworks MX 2004+) is use the rounded rectangle auto shape. That shape gives you the option of rounding corners individually (using the ALT key I think). Then you can make two and round the left corners on one and the right corners on the other giving you the same effect as a rounded rectangle cut in two but still retaining editability for the rounded corners.
                • 5. Re: rounded corners
                  Level 7
                  In FW8 it's all doable numerically through the AutoShape Properties
                  panel... quicker and much more precise than dragging control points with
                  the mouse.
                  St�phane Bergeron
                  reach : connect : communicate
                  http://www.webfocusdesign.com
                  blog : tutorials : articles : gallery
                  http://www.pixelyzed.com
                  • 6. Re: rounded corners
                    Level 7
                    "St�phane Bergeron" <news@webfocusdesign.com> wrote in message
                    news:e4a3p6$b2v$1@forums.macromedia.com...
                    auto
                    (using
                    on one
                    rounded
                    corners.
                    | the mouse.
                    And there's always the trusty Fillet command from...
                    http://www.projectfireworks.com/Lab.aspx?show=extension_fw_3_4.html
                    Peter
