4 Replies Latest reply on May 16, 2006 2:44 AM by rechtut
    accesing externally loaded variables
    rechtut Level 1
      i would greatly appreciate a pointer or two as i am having a painful transition to AS2.0
      an 8k zip test is at: www.cyan-animatica.com/v2/exttest.zip //(wasn`t there an option back in macromedia days to attach a file?)
      i am having a poblem accesing externally loaded variables :
      A.--------------------------------------------------------------------
      the external .txt has folowing content:
      &a1_0=hello&a1_1=bye&a1_2=whatever
      B.--------------------------------------------------------------------
      loaded on the first frame thus:
      var thumbs:LoadVars = new LoadVars();
      thumbs.onLoad = function(success:Boolean):Void {
      if (success) {
      trace("LoadVars loaded successfully: "+this.loaded);
      } else {
      trace("Error");
      thumbs.load("my_externals.txt");
      C.--------------------------------------------------------------------
      if want to access one of 3 loaded variable hardcoding, this works just fine:
      trace(_root.thumbs.a1_1) //bye
      BUT i need to do this based on the mc/buton name that calls it:
      on (press) {
      var kk:String = _name;
      trace(_root.thumbs.kk);
      i get UNDEFINED...obviously i am mixing datatypes if not worse
      pc win 2000
      flash prof for flash8 player[
        • 1. Re: accesing externally loaded variables
          blemmo Level 1
          I don't really understand the problem, but when you want to add vars to the LoadVars object, it has to be referenced correctly:
          on (press) {
          _root.thumbs.kk = _name;
          Is that what you wanted to do?
          cheers,
          blemmo
          • 2. Re: accesing externally loaded variables
            rechtut Level 1
            thanks for a prompt reply, blemmo.
            you write:<<to ADD vars to the LoadVars object, it has to be referenced correctly
            what i want to do is READ vars from LoadVars object and referencing is exactly what is killing me
            sorry bout the lack of clarity. the zip would help (www.cyan-animatica.com/v2/exttest.zip)
            i am loading 3 variables into an object var thumbs:LoadVars
            from one external .txt file:
            a1_0=hello
            a1_1=bye
            a1_2=whatever
            i want to see the contens of let us say the second variable
            trace(_root.thumbs.a1_1);
            produces bye , perfectly - this is exactly what i want, but i want it based on a constructed reference
            so, i have button in an mc named "a1_1", the button script is:
            on (press) {
            trace(kk); // produces a1_1
            trace(_root.thumbs.kk); //this should be same as _root.thumbs.a1_1 and produce the same result, but does not
            i suspect that the problem is that kk is declared as string datatype, but no matter what i do i cannot get a result
            thanks for your help
            • 3. Re: accesing externally loaded variables
              TwiceAlive100
              Try this:
              on (press) {
              trace(_root.thumbs[kk]);//use brackets instead of referencing by "."
              • 4. Re: accesing externally loaded variables
                rechtut Level 1
                thank you for you time and effort blemmo
                and thank you TwiceAlive100 - you are 100% on the money
                it just an array, isn´t it? and i was going at it ***-backwards
