• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Has anyone used scripts in FrameMaker 2015?
Community Beginner ,
Jan 11, 2016 Jan 11, 2016
Hi everyone,
We have some relatively complex scripts we use to update books in FrameMaker 10. Now that we are running them on FrameMaker 2015, the results are mixed. We are parsing out each function and doing some testing, but I wanted to check here if anyone has any experience running scripts in FM2015.
If we get the issue narrowed down, I will try to share our results here.
Thanks for your feedback!!
Heather Ayer
TOPICS
Scripting
Views
506
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Hi Heather,
I haven't seen any specific problems with FrameMaker 2015 and ExtendScript. If you let me know what you are seeing, I might be able to steer you in the right direction.
Rick
PS. I just left you a voice mail. Call me if you want discuss it over the phone. Thanks.
Votes
Translate
Translate
Report
Report
Mentor ,
Jan 12, 2016 Jan 12, 2016
Heather, same here. I run lots of scripts and have not noticed any problems in FM2015. Yet.
Russ
Votes
Translate
Translate
Report
Report
Nov 22, 2017 Nov 22, 2017
I see this is an old post, but it's the closest thing to the issue I'm seeing.
A major problem I am having with extendscript with FM2015 is that it seems to not be resetting the text location properly when I run repetitive finds in a script.
So, if I set
tloc = new TextLoc (docStart, 0);
with tloc being the variable for test location and docstart being the first paragraph in the flow, and then run
foundText = doc.Find (tloc, findParams);
it doesn't run the search from the defined text location (tloc). Even though I look at the tloc variable in data browser (or have it pop up in an alert), and it says '0', the find will start from some weird offset.
I have seen this in multiple scripts that worked fine in FM11, but now do not reset the start location properly for a Find.
Was there some change in the way the text locations are manipulated in FM2015?  Anyone else having similar issues?
I do a lot of find/change or find and manipulate in scripts across 500+ page books. I need to be able to precisely position the start of the find or it's very difficult to know what is going on.
thanks for any responses (or words of encouragement!).
Votes
Translate
Translate
Report
Report
Community Expert ,
One thing I have had to do with these is to "reset" the current text selection to the text location I just made before I do the find. Something like this:
doc.TextSelection = new TextRange (tloc, tloc);
Rick
Votes
Translate
Translate
Report
Report
Nov 30, 2017 Nov 30, 2017
LATEST
I'll give this a shot and let you know. Thanks for the help!
Votes
Translate
Translate
Report
Report
