2 Replies Latest reply on Jan 12, 2016 6:47 AM by robdillon
    How to change the code to include Minimum number as well ...
    FlashLearner
      I have downloaded the file form the following website.
      Random number generator – Roy Tanck’s weblog
      http://www.roytanck.com/wp-content/uploads/randomnumber.zip
      There is a input box for Maximum number but no input box for Minimum number. I want to put I more input textbox on form for Minimum Number (Instead of "1"). So, how to change the following code to work properly? Suppose, if I want to get random number between 150 to 350, how can I?
      input_txt.restrict = "0-9";
      if( maxNr != undefined ){
        input_txt.text = maxNr;
      switch(maxNr){
        case 1:
        easter_txt.text = "Wow ! You are LUCKY";
        break;
        case 42:
        easter_txt.text = "\"I checked it very thoroughly, it's 42\"";
        break;
        case 666:
        easter_txt.text = "Lucky Number !!!";
        break;
        case 999999999999999:
        easter_txt.text = "That's almost a quadrillion!";
        break;
        default:
        easter_txt.text = "";
        break;
      go_btn.onRelease = function(){
        maxNr = Math.max( Number( input_txt.text ) , 1 );
        gotoAndStop("random");
      stop();
      //maxNr = 999999999999999;
      initRandom = function(){
        var nr = Math.ceil(Math.random()*(maxNr));
        var nrString = "";
        for( var j=0; j<(maxNr.toString().length-nr.toString().length); j++){
        nrString += "0";
        nrString += nr.toString();
        var holder = this.createEmptyMovieClip("holder",1);
        for( i=0; i<maxNr.toString().length; i++ ){
        var mc = holder.attachMovie("number","n"+i,i+10);
        mc._x = i*90;
        mc.anim_mc.gotoAndPlay( Math.floor(Math.random()*9) + 1 );
        this["iv"+i] = setInterval( this, "revealNumber", 2000 + (500*i), nrString.substr(i,1), i );
        // scale (if needed) and center
        if( holder._width > Stage.width ){
        holder._width = Stage.width;
        holder._yscale = holder._xscale;
        holder._x = Stage.width/2 - holder._width/2;
        holder._y = 40;
        // buttons
        back_btn.onRelease = function(){
        for(item in holder){
        holder[item].removeMovieClip();
        gotoAndStop("intro");
      revealNumber = function( digit, i ){
        clearInterval( this["iv"+i] );
        holder["n"+i].gotoAndStop("done");
        holder["n"+i]["number_txt"].text = digit;
      initRandom();
      stop();
