10 Replies Latest reply on Jan 12, 2016 10:40 AM by coredvideo
    GTX illusions
    coredvideo Level 1
      Hey there,
      I've been using EVGA GTX 760 2GB ACX since 1 year and very satisfied with it.
      Now i'm building a new machine and can't decide which card should i get? Don't need over expensive card which doesn't goes with my Intel i7 4th generation mid budget machine lo
      So two cards i'd lined up
      ASUS GTX 670 2GB Direct CU II
      Workflow will be 1080p editing
      adobe PR cc 2015
        • 1. Re: GTX illusions
          cc_merchant Level 4
          Both are good and have similar performance. Your choice.
          • 2. Re: GTX illusions
            ECBowen Most Valuable Participant
            I would suggest the 960GB 4GB card.
            Eric
            ADK
            • 3. Re: GTX illusions
              RoninEdits Most Valuable Participant
              for 1080p as the OP says he will be doing, why spend money on a similar performing gtx 960? will 4gb memory help with 1080p?
              • 4. Re: GTX illusions
                Yes but the 960GTX 4GB card would be future proofing for changes in workflow and GPU acceleration support.
                Eric
                ADK
                • 5. Re: GTX illusions
                  coredvideo, do you already own one or both of those cards? if both, you could actually use both together if you have a motherboard that supports multiple video cards (ie 2 gpu's at 8x pcie lanes). premiere supports multiple video cards, and since those are somewhat similar in performance, they should work together ok. that might be overkill for your 1080p projects and as well as demanding for your psu, so it may not be worth bothering with. if you do not have either video card then the gtx 960 4gb eric suggests would be an option, or finding a used older card for cheap. the long standing advice around here has been a 2gb card for 1080p and 4gb for 4k timelines. im not sure if something changed as to why eric now says 4gb for 1080p, but he is one of the top experts.
                  • 6. Re: GTX illusions
                    coredvideo Level 1
                    Eric,
                    EVGA GTX 960
                    • Base Clock: 1304 MHZ
                    • Boost Clock: 1367 MHz
                    • Memory Clock: 7010 MHz Effective
                    • CUDA Cores: 1024
                    • Bus Type: PCI-E 3.0
                    • Memory Detail: 4096MB GDDR5
                    • Memory Bit Width: 128 Bit
                    • Memory Speed: 0.28ns
                    • Memory Bandwidth: 112.16 GB/s
                    Asus GTX 670
                    Chipset Manufacturer
                    NVIDIA
                    GPU
                    GeForce GTX 670
                    Core Clock
                    915MHz
                    Boost Clock
                    980MHz
                    CUDA Cores
                    1344
                    Memory
                    Effective Memory Clock
                    6008 MHz
                    Memory Size
                    2GB
                    Memory Interface
                    256-Bit
                    Memory Type
                    GDDR5
                    • 7. Re: GTX illusions
                      coredvideo Level 1
                      Eric,
                      Should I go for GTX 960 just for more ram?
                      • 8. Re: GTX illusions
                        The 900 series cards have hdmi 2.0 and support several 4K displays besides the 960GTX having 4GB vram options so overall it's better money spent. 1080 media in Premiere specifically wont use more than 2GB of vram but that is always subject to change. If you change to higher resolution media then you definitely want the 4GB. So overall the 960GTX is a better option for later. If it's completely about budget and the 960GTX is to much then the 760GTX would be an equivalent card. However the 700 series have been out of production so not the best choice.
                        Eric
                        ADK
