9 Replies Latest reply on Jan 31, 2009 8:29 AM by Newsgroup_User
    problem in accessing web service
    vikceo
      Hie I am trying to access my webservice and getting
      Error #1085: The element type "meta" must be terminated by the matching end-tag "</meta>".
      any suggestions?
        • 1. Re: problem in accessing web service
          markuspedro Level 1
          hi,
          if you have this error when you try to communicate with ws probably you send params to web service, but the xml is not well formed.
          Else, if you have this error during compiling you must sure that the code is well formed
          <a>
          <meta></meta>
          </a>
          All tag must be open and closed
          By marco
          • 2. Re: problem in accessing web service
            vikceo Level 1
            Well i m getting this error while communicating with WS.
            I have created this ws using jdeveloper and i can test it in jdeveloper where it shows the right thing. i mean well formed xml.
            Strange thing is i dont see the meta tag anywhere when i test my ws in jdeveloper. So, even not sure what actually is causing this.
            • 3. Re: problem in accessing web service
              Level 7
              "vikceo" <webforumsuser@macromedia.com> wrote in message
              news:glvael$q57$1@forums.macromedia.com...
              > where
              Look at it from a browser
              • 4. Re: problem in accessing web service
                vikceo Level 1
                ok so this is what i see in my browser
                <env:Envelope
                xmlns:env=" http://schemas.xmlsoap.org/soap/envelope/">
                <env:Header/>
                <env:Body>
                <ns0:startFetchingResponse
                xmlns:ns0=" http://headcountservice/">
                <return
                xmlns="">
                <country>USA</country>
                <creationDate>2009-01-27 11:50:33.0</creationDate>
                <headCount>1</headCount>
                </return>
                <return
                xmlns="">
                <country>OTHER</country>
                </return>
                </ns0:startFetchingResponse>
                </env:Body>
                </env:Envelope>
                • 5. Re: problem in accessing web service
                  vikceo Level 1
                  so i don't see the word meta any where and this is well formed. any suggestions?
                  • 6. Re: problem in accessing web service
                    bitwyse Level 1
                    You should check out a web service proxy tool called Charles. You can see all the information to / from a web service. It's an amazing tool. Google Charles Web Service Proxy you'll find it.
                    • 7. Re: problem in accessing web service
                      Level 7
                      news:glvev7$2be$1@forums.macromedia.com...
                      > suggestions?
                      What is the code that is erroring out?
                      • 8. Re: problem in accessing web service
                        vikceo Level 1
                        hie
                        here is the code:
                        <mx:HTTPService id="headCountService"
                        resultFormat="e4x"
                        fault="headCountService_fault(event);"
                        result="headCountService_result(event);"
                        url=" http://localhost:8988/HeadCount-HeadCountService-context-root/headcountwssoaphttpport"/>
                        private function headCountService_fault(evt:FaultEvent):void {
                        var title:String = evt.type + " (" + evt.fault.faultCode + ")";
                        var text:String = evt.fault.faultString;
                        alert = Alert.show(text, title);
                        private function headCountService_result(evt:ResultEvent):void {
                        var statListAll:XMLList = new XMLList(evt.result.stat);
                        I am calling the service in the main mxml file as
                        <mx:WindowedApplication xmlns:mx=" http://www.adobe.com/2006/mxml"
                        showFlexChrome="false"
                        layout="vertical"
                        preinitialize="headCountService.send();">
                        And error is coming from the method headCountService_fault
                        • 9. Re: problem in accessing web service
                          Level 7
                          news:gm1pl9$s5h$1@forums.macromedia.com...
                          > hie
                          > here is the code:
                          > resultFormat="e4x"
                          > aphttpport"/>
                          > layout="vertical"
                          Is it possible that your web service is receiving something with an ill
                          formed tag. I'd second bitwyse's suggestion.
