• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
7
How to Reverse Pages Order in Acrobat Pro DC
Community Beginner ,
Jan 12, 2016 Jan 12, 2016
Old problem but the Javascripts out there are not working for me and the whole implementation of scripts in Acrobat Pro DC has become more difficult.
I get books that are scanned back to front so the PDF has page 300 of the book as page 1 of the PDF and page 300 of the PDF is page 1 of the book
I just need to select all pages and reverse their order. But this does not seem to be an option in any of the tools for editing, organizing pages.
The Javascripts out there used to add a menu item under the "Documents" menu:
app.addMenuItem({ cName: “Reverse Page Order”, cParent: “File”, cExec: “PPReversePages();”, cEnable: “event.rc = (event.target != null);”, nPos: 0
function PPReversePages()
var t = app.thermometer;
t.duration = this.numPages;
t.begin();
for (i = this.numPages – 1; i >= 0; i–)
t.value = (i-this.numPages)*-1;
this.movePage(i);
t.text = ‘Moving page ‘ + (i + 1);
t.end();
}// JavaScript Document
but I find no means to run this script...
TOPICS
Edit and convert PDFs
Views
38.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
correct answers 2 Correct answers
Community Beginner , Jan 13, 2016 Jan 13, 2016
NO... I went to
~Users/MyDrive/Application Support/Adobe/Acrobat
and there was no "JavaScript" folder there... I made one, put in the script and restarted Acrobat:  "Nada" nothing.
So back to the web and search:  I found this solution which does work;
In Acrobat Pro DC  Go to
  1. Tools --> [scroll all the way down] -->
  2. Customize -->
  3. Action Wizard -->
  4. New Action --> [Scroll down under left panel "Choose Tools to add: -->
  5. More Tools -->
  6. Execute JavaScript -->
  7. the new action will appear on the right panel --
Votes
Translate
Translate
Community Expert , Jul 10, 2016 Jul 10, 2016
You can use this free script I've developed. It comes with detailed installation instructions.
Custom-made Adobe Scripts: Acrobat -- Reverse Page Order (FREE)
Votes
Translate
Translate
Community Expert ,
Do you not see it under the File menu?
Votes
Translate
Translate
Report
Report
NO... I went to
  2. Customize -->
  5. More Tools -->
  7. the new action will appear on the right panel -->
  8. Set your defaults: I left it on  -- Files to be Processed --> Currently open file as default"
  9. Under the "Execute Javascript" click on -->
  10. Specify Settings   (Why doesn't it say "Enter Your Script" ??)
  11. another panel opens... paste in this script:
  12.     for (var i = this.numPages - 1; i >= 0; i--) this.movePage(i);
  13. click OK to close and then save the action...
  14. You will be prompted to name the action,
  15. name it " Reverse Page Order"  and save..
  16. Now new action appears in the action wizard Actions List "Reverse Page Order"
it works!
<mini-rant>
IMHO older versions of Acrobat had a scripts menu at the top of the screen, over on the right, totally accessible.
Of course if you were not "into" JS you could just ignore it... but if you *do* use scripts it was not buried.
This new UX is one of the worst possible scenarios imaginable.
Perhaps the Acrobat team lost it's top UX people?
</mini-rant>
Votes
Translate
Translate
Report
Report
New Here ,
If this used to work (I believe you), it doesn't work now because there is no "More Tools" in the "Choose Tools to add dialog box. This Javascript:
is all well and good, but I can't find the place in the interface to put it. Did they delete "More Tools"? There is a "More Tools" under "Action", but it goes out to the web.
This seems like such a common, simple problem, why isn't there a solution built in to Acrobat? I am underwhelmed and over irritated at the complexity of the interface that initially gives one the illusion of simplicity.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 15, 2021 Mar 15, 2021
Just wanted to clarify how to insert script correctly:  via Acrobat Pro DC 2021
/* Reverse Page Order */for (var i = this.numPages - 1; i >= 0; i--) this.movePage(i);
Votes
Translate
Translate
Report
Report
Community Expert ,
Run the script in the console window, not in the document.
You'll find a tutorial on the console here:
https://www.pdfscripting.com/public/Free_Videos.cfm#JSIntro
Thom Parker - Software Developer at PDFScripting
Use the Acrobat JavaScript Reference early and often
Votes
Translate
Translate
Report
Report
Feb 02, 2022 Feb 02, 2022
LATEST
The menu was slightly different but I was able to get through this without much difficulty and it worked perfectly.  AWESOME!  Thanks for the guidance...
Eric
Votes
Translate
Translate
Report
Report
New Here ,
nope.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Jul 13, 2016 Jul 13, 2016
Your custom-made script worked like a charm for me on latest Adobe Acrobat Pro DC 2015 Release.
Easy download of javascript and instructions clear for me using"/Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Resources/JavaScripts/ReversePagesOrder.js".
Thank you try67, saved me much angst and I am grateful for your work – can recommend.
Noel
Votes
Translate
Translate
Report
Report
Contributor ,
Dec 11, 2018 Dec 11, 2018
Thank you!
Votes
Translate
Translate
Report
Report
Engaged ,
Apr 02, 2019 Apr 02, 2019
I am sure it is a wonderful script.
I have submitted my email address twice (one has to provide an email address in order to be able to download it from https://www.payloadz.com/d1/default.aspx?id=2749650 )
I did not receive anything though (checked my junk folder, nothing there either).
Votes
Translate
Translate
Report
Report
Community Expert ,
Send me an email and I'll send it to you directly.
Votes
Translate
Translate
Report
Report
Engaged ,
Apr 04, 2019 Apr 04, 2019
Thank you very much indeed. Downloaded and installed the script. It works fine and very fast. Really super!
Again, many thanks!!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 26, 2020 Mar 26, 2020
Thanks very much try67 - this worked great. Downloaded the two files and placed in the required folder after ticking the right boxes in Adobe as suggested in your text file. Then started up the Adobe app and loaded in my file again. Searched for the tool and there it was - with figers crossed I clicked on the icon and sure enough the pages were in reverse order instantly. Very clear instructions and a really neat js file - Once again many thanks for the solution. Still amazed that such a fundamental task is not a standard feature.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 27, 2020 Jul 27, 2020
Woww! Try67, your script worked amazingly!
The only tip I would make more explicit in the instructions, is the first steps for newbies like myself to adding these features to Adobe. I had a hard time finding the correct JavaScript folder on my computer using Adobe DC using MacOS High Sierra. I also searched for "JavaScript" in the Finder search box for my whole computer but no such folder came up.
This worked:
1. In Finder, Go > Computer
2. MacIntosh HD > Applications > Adobe Acrobat DC.
3. Right-click on Adobe Acrobat program icon in the Adobe Acrobat DC folder, and select "Show Package Contents"
4. Contents > Resources > JavaScripts
5. Paste Gilad's (try67) file in the JavaScripts folder, AFTER reading the instructions on how to set up your JavaScript preferences in Adobe Acrobat, and closing Acrobat. (Both downloaded from http://try67.blogspot.com/2014/10/acrobat-reverse-page-order-free.html).
When I reopened Acrobat, it worked a charm!! I had a 250-page ancient Hebrew book scanned by an American university library the wrong way around.  A manual reordering would have taken me hours. Now I feel like a computer ninja. Thank you Gilad, and I'll send you a tip on PayPal now!
Votes
Translate
Translate
Report
Report
New Here ,
Sep 22, 2016 Sep 22, 2016
This worked for me, thanks!
Votes
Translate
Translate
Report
Report
New Here ,
Jan 11, 2017 Jan 11, 2017
Thank you for this.
You just saved me a day!
Worked today on
Acrobat Pro DC
on MAC (OS 10.12.2)
Votes
Translate
Translate
Report
Report
New Here ,
Jun 01, 2017 Jun 01, 2017
Thanks... It works just as you said!
I'm on a Mac with Acrobat DC Pro (2017.009.20044)
Votes
Translate
Translate
Report
Report
New Here ,
Feb 07, 2018 Feb 07, 2018
THANK GOODNESS!! You saved me hours. I had 100 pages backwards and now I'm golden. I bow to you.
Votes
Translate
Translate
Report
Report
New Here ,
May 11, 2018 May 11, 2018
It works! Many thanks
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 21, 2018 Jul 21, 2018
You are my HERO. BLESS YOU. THANK YOU. I owe you coffee. And a million dollars.
Votes
Translate
Translate
Report
Report
Engaged ,
Mar 03, 2019 Mar 03, 2019
Thank you so much Brahmanatha!
Your solution worked very well.
The old .sequ files that I could find on Internet, one way or the other they didn't work on Acrobat 2017
Again, many thanks indeed!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 20, 2019 Mar 20, 2019
Excellent. Many thanks for this.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 22, 2019 Jun 22, 2019
Thank You many many times. Brahmanatha, you are so great !!!
Votes
Translate
Translate
Report
Report
