3 Replies Latest reply on Jan 13, 2016 8:50 AM by Rick Gerard
    How to export after effect into swf
    arvyt62488061 Level 1
      this is my first time i using after effect and want save my practice into swf.
      i already search and find a lot similiar question like mine and i try the problemsolve but my problem still there haha
      im using AE cs6, doing practice i make some motion with 3 composition in the end
      1st compostion is the original one, motion run around 3s
      2nd composition is the reverse time from the 1st composition
      3rd composition is some motion typograhy
      if i save/render into movie file, its work fine its run for 7s
      but when i save into swf so it can loop continuously, only 1st compostion play in that swf file, 2nd&3rd composition didnt show
      i try different setting when save to swf, but still same
      what i miss, so all my composition can played when i save into swf
      thanks
        • 1. Re: How to export after effect into swf
          Do you have all three compositions placed together in the same master composition?
          Why do you want a SWF from AE? Usually it's better to render an FLV video file with the Adobe Media Encoderand use Flash to embed it in a SWF.
          • 2. Re: How to export after effect into swf
            sorry i still dont really know what should i save to be frank, i only try AE in this last 2 day
            i try to save into swf since...maybe that the only format i know can play loop continuously, its just fun to see the final work like that
            so what the common/best setting ppl use for save their work with after effect?
            btw this is my final composition, something i missed so the swf file didnt save correctly?
            i save with setting like this : jpg size : high, unsupported feature : rasterize (since when i pick ignore, the result only blank white page swf) and loop continuosly : cheked
            • 3. Re: How to export after effect into swf
              AE creates video not flash content. You'll need flash for that. You can loop a video using an HTML 5 player.
              There is no dpi or poi in video because there are no inches in video, just pixels. It's the same for the web. A 1ppi jpeg that is 200 X 200 pixels will be 200 X 200 pixels wide in video or on a web page. If you change the PPI of that image to 999ppi and keep the dimensions at 200 X 200 pixels then the image will still be 200 X 200 pixels in a video or a web page. The only time you will get a different size for an image with the same pixel dimensions but different PPI (DPI of for scanners or dot matrix printers) is if you send the image to a printer using software that uses PPI for sizing the image.
              If you have problems rendering an F4V for flash then just render an h.264.mp4 and then change the extension and use Flash to play the loop. Flash will also loop an mp4 so it's kind of a no brainer. The only time you would have to render an f4v for flash is if you need transparency but html 5 media players do not support transparency so you're kind of barking up the wrong tree there if you want your video to work on a mobile device.
