The problem is:
I am creating a simple presentation file on how to create a
shortcut and rename it Windows file view. Everything is fine, I
open the directroy, open the sub-directroy, right click the file
and select "Create Shortcut" from the menu, A shortcut is created,
then I right click the shortcut and modify the name and click off
the newly renamed shortcut and press END.
When I play it back in a browser, when I right click the file
to create the shortcut, the next slide is the very first slide
(where I started the presentation) is inserted (not the slide I
recorded) in my presentation which has another directroy selected,
and a highlighted area, and a caption that says "Select Create
Shortcut" from the menu. After this slide happens everything
reverts to the presentation correctly. This slide pops up no matter
how many times I re-create the presentation.
In other words I record the slides as follows
1, 2, 3, 4, 5, 6,
When I play them back after recording they are in this order.
1, 2, 3, 1, 5, 6,
The first slide is inserted where the 4th one should be. I
have no idea what it does with the 4th slide, it is there, but for
some reason only known to Captivate it ignores it and inserts the
first slide again in lieu of the 4th.
Working on another presentation where I create a shortcut and
rename it, Captivate exhibits the same behavior as my first
presentation.
