13 Replies Latest reply on Jan 24, 2016 1:57 PM by Nooday
    need technical advice on HDD
    Nooday
      Hello friends,
      I will buy a new PC and I need your help on two questions.
      Question 1:
      I need an I7 processor for mounting 4K with the Twixtor plugin and Colorista III
      I must make a choice between I7 5930k or I7 5960X.
      after the test PassMark: http://www.cpubenchmark.net/high_end_cpus.html
      their performance are substantially similar.
      you think the I7 5930K enough?
      Question 2:
      HDD configuration
      the new SSD 950 Pro, is a speed monster, I aimarais know what you think of this configuration:
      - 256GB SSD 850 PRO: Windows 10 + Software
      - 2 X 850 PRO 256GB SSD RAID 0: Cache & Media Previews
      - 500GB SSD 950 PRO: Media & projects & Exports
      the rest of my configuration:
      32GB DDR 4
      GTX 980ti
      Thank you in advance for your assistance.
        • 1. Re: need technical advice on HDD
          RameezKhan Adobe Employee
          Moving to Premiere Pro Hardware Forum
          Rameez
          • 2. Re: need technical advice on HDD
            cc_merchant Level 4
            1. Depends on the threading capabilities of your plugins. If they thread lousy, the 5930 is OK, if they thread good, the 5960 is the preferred one.
            2. Sounds OK.
            3. The GTX 980Ti is overkill for Premiere Pro sec. If your plugins use the video card extensively, it is OK. If they hardly use the video card, you may as well throttle down to a 970.
            For the impact of the video card, see Tweakers Page - What video card to use
            • 3. Re: need technical advice on HDD
              Bill Gehrke Most Valuable Participant
              I would not bother putting those two 850 Pro's into a RAID 0 array.  You are not going to see any advantage running Premiere over a single one.  And personally I leave the Media Cache and Media Cache Files in the default position on the boot SSD and put the Preview files on the Samsung 950 Pro drive which is so much faster.  This is on my X99 i7-5960X.which is the current fastest Premiere Pro BenchMark (PPBM) system, you will have to register on the site to see the results.
              • 4. Re: need technical advice on HDD
                Nooday Level 1
                thank you for your answers, but I believe that you disagree on the HDD configuration
                RameezKhan agrees with this:
                - 2 X 850 Pro SSD 256GB RAID 0: Cache & Media Previews
                - 500GB SSD 950 PRO: Media & Projects & Exports
                but this is what proposes "Bill Gehrke" (if I understood correctly?)
                - 256GB SSD 850 PRO: Windows 10 + Software +
                - 850 Pro SSD 256GB RAID 0: Cache
                - 500GB SSD 950 PRO: Previews & Digital Media & Projects & Exports
                you advise me which SSD configuration?
                about the graphics card I agree with you, but I work too much on photoshop, lightroom, after-effects, Cinema 4D, 3D elemend
                that's why I chose the gtx 980TI is just to have the margin
                thanks for your help
                • 5. Re: need technical advice on HDD
                  RoninEdits Most Valuable Participant
                  i believe this is what bill proposes:
                  - 256GB SSD 850 PRO: Windows 10 + Software + Cache
                  - 512GB SSD 950 PRO: Previews & Digital Media & Projects & Exports
                  if you do not have enough room on the 950 pro for previews and AE disk cache, then you will need another drive to have enough storage space. in that situation your original setup will be fine.
                  the i7-5820k and 5930k once overclocked are similar speeds, but the 5960x is a fair bit faster with 2 more cores. the broadwell-e 10 core i7-6950x will be an upgrade option for the x99 platform, so you could just go with the 5820k to holdover till then.
                  • 6. Re: need technical advice on HDD
                    Thank you Ronin for correcting that wrong assumption.  There is no performance improvement for Premiere going from one 850 Pro to a RAIDed pair of drives if you needed more room and decide to add the three drive.  I have made several tests on the Media Cache and Media Cache Files and found I could put those folders on an old USB 2 storage drive and could see no difference in performance.
                    • 7. Re: need technical advice on HDD
                      Nooday Level 1
                      thank you, Ronin and thank you Bill
                      I have 2 hard drive that could be used:
                      1 X Hitachi 1to 7200tr
                      1 X Vélociraptor 150go 10000tr
                      it should be good like that?
                      - 1 Hitachi X 1to 7200: Cache
                      thank you,
                      • 8. Re: need technical advice on HDD
                        Nooday Level 1
                        Last issue we I7 5960X you think I do not regreterai this purchase order are prices? I really hesitate ^^
                        • 9. Re: need technical advice on HDD
                          Nooday Level 1
                          Hello friends,
                          I must be lost
                          here is the last of configue Mr.millaard at:
                          http://ppbm7.com/index.php/choosing-the-storage
                          I'm surprised he chooses the ssd 950 pro for windows
                          Volume
                            Purpose  Disk  Raid array Ind. R Speed Ind. W Speed
                          C:  OS & programs, page-file  Samsung 950 Pro 512GB  NA2200 MB/s1500 MB/s
                          D:  Media cache & previews  Samsung 850 Pro 256GB  4 x in Raid02200 MB/s2000 MB/s
                          E:  Media & projects  Samsung 850 Pro 512GB  9 x in Raid34000 MB/s
                          4000MB/s
                          F:  Backup & exports  Seagate Constellation 1TB  15 x in Raid302700 MB/s2700 MB/s
                          • 10. Re: need technical advice on HDD
                            I much prefer the Boot/OS/applications drive to be a standard SATA III like a Samsung 850 Pro and use the Samsung 950 Pro for all the Premiere Pro project files.  Forget about RAID except for archiving and backup.
                            The total for the above configuration of 15 hard disk drives, 14 SSD's, and 2 Areca disk controllers is $6527!
                            • 11. Re: need technical advice on HDD
                              Nooday Level 1
                              we agree, here is my setup
                              Volume
                                Objectif  Disque  Matrice RAIDInd. R VitesseW Ind. Vitesse
                              C:  OS et programmes, la page-fichier Samsung 850 Pro 256 Go  2 200 Mo / s1500 Mo / s
                              D:  Cache des médias et les prévisualisations  Samsung 850 Pro 256 Go500 Mo / s? Mo / s
                              E:  Médias et projets  Samsung 950 Pro 512 Go  2 200Mo / s
                              1500 Mo / s
                              F: exportations Velociraptor 150go 120 Mo / s90Mo / s
                              G:   Backup 2 X 4to
                              • 12. Re: need technical advice on HDD
                                Do not export to that lousy Disk drive use your 950 Pro for your exports also.
                                • 13. Re: need technical advice on HDD
                                  Nooday Level 1
                                  Thank you Bill Gehrke
                                  I just ordered the Monster I receive it Friday;)
