1 Reply Latest reply on Jan 29, 2009 2:00 PM by flexchief
    SQLite attach database table error
    flexchief
      I'm trying to attach a database(db2.sqlite) to a currently open database(db1.sqlite) and copy the contents of one of the tables in db2 into one of the tables in db1. The logical way to do this I thought was to use the attach command and then select all from db2 and insert into db1:-
      attach 'C:\db2.sqlite' as newData;
      insert into main.table1 select * from newData.table1
      Both database's have identical table names (table1) and the exact same schema. To make sure my syntax was correct I tried this out in the Firefox SQLite Manager and everything worked perfectly.
      Unfortunately when I tried the same method in my air application I got the following error:-
      "ATTACH is not allowed from SQL.', operation:'execute', detailID:'2053'"
      Can someone please tell me why this isn't working?
      Adam
      Flexchief
