1 Reply Latest reply on Jan 29, 2009 9:17 AM by Joe ... Ward
    User Alias
    fypstudent
      I wanted to create an user alias where users are able to change their nickname easily. I had created an input box for users to enter their name. However, when I restart the application again, the name is not stored. How do I go about storing the information/value users had entered?
      Codes:
      //////////userAlias.as////////////////////////
      package {
      import flash.display.Sprite;
      import flash.display.Stage;
      import flash.text.*;
      import flash.events.*;
      public class userAlias extends Sprite{
      private var myTextBox:TextField = new TextField();
      private var myText:String = "Type your text here.";
      public function userAlias() {
      myTextBox.type = TextFieldType.INPUT;
      myTextBox.background = true;
      myTextBox.height = 14;
      myTextBox.width = 93;
      var format:TextFormat = new TextFormat();
      format.font = "Arial";
      format.size = 9;
      myTextBox.defaultTextFormat = format;
      addChild(myTextBox);
      myTextBox.text = myText;
        • 1. Re: User Alias
          Joe ... Ward Level 4
          For something simple like this, the flash.net.SharedObject class provides an easy way save a value. You will have to add an event listener to detect when the value is changed so that you can call a routine to save a new value. And, of course, need to read that value when your application starts up.
          You can also save data in a file, store data in a local database, or use the encrypted local store.
