12 Replies Latest reply on Feb 13, 2016 2:52 PM by Elwissan
    How to duplicate three rectangles at once without grouping?
    Elwissan
      Each rectangle is on a different layer.
      Duplicate a rectangle at a time I can, but not that way.
      I will duplicate the rectangles in the second document.
      At most I could like this: (But it can not be so because it has to be specific rectangles.)
              function ItemByRange(){
                  var sourcepage = app.documents[0].pages[0];
                  var destpage = app.documents[1].pages[0];
                  sourcepage.pageItems.itemByRange(app.documents[0].pages[0].rectangles[1], app.documents[0].pages[0].rectangles[4]).duplicate(destpage);
      I use InDesign CS6 and CC, JSX, .vbs. Mac and PC.
      Thank you!
        • 1. Re: How to duplicate three rectangles at once without grouping?
          Elwissan Level 1
          I'm working on this code, but also failed.
          myAttempt_14();
          function myAttempt_14(){
              var sourceDoc = app.documents[0];
              var myRectamgle1 =  sourceDoc.pages[0].pageItems[0];
              var myRectamgle2 =  sourceDoc.pages[0].pageItems[1];
              var myRectamgle7 =  sourceDoc.pages[0].pageItems[6];
              var myObjs  = new Array();
              myObjs.push (myRectamgle1);
              myObjs.push (myRectamgle2);
              myObjs.push (myRectamgle7);
              sourceDoc.select(myObjs, SelectionOptions.addTo);
          //~ The following code is wrong.
              sourceDoc.selection.itemByRange(sourceDoc.selection[0],sourceDoc.selection.length-1).duplicate(destpage);
          //~ It is in this line I'm working on now. I'm trying.
          • 2. Re: How to duplicate three rectangles at once without grouping?
            Jump_Over Level 5
            Why to duplicate "at once" is so important for you?
            Jarek
            • 3. Re: How to duplicate three rectangles at once without grouping?
              Elwissan Level 1
              Hi Jarek,
              It is not very important, but it would be interesting.
              In fact what is important to me:
              Duplicate a set of objects (Rectangles, TextFrames, lines, images, groups) to the second document without changing the position between them.
              However, each item is different layer. And that I also have to preserve.
              In the second document the set will have a new position (on top of page, eg [0,0]).
              Summing up
              When duplicate:
              1. Maintaining the position of the objects between them.
              2. Keep each item in your layer
              3. Move the set of objects for a new position on the page of the second document.
              Elvis
              • 4. Re: How to duplicate three rectangles at once without grouping?
                Trevorׅ Adobe Community Professional
                I second Jarek's comment.
                But if you one stupid way of doing it would be app.copy() and app.paste();
                But then all 3 would go onto the same layer in the target document which is probably not what you want.
                • 5. Re: How to duplicate three rectangles at once without grouping?
                  Mikie9 Level 1
                  Here I have the preference set,  "Paste Remembers Layers" to get around this. Some snippets I place have to go to specific layers, and this solves that too. I don't know what it would be in code but that may solve the layer issue. I don't recall if that was an option in CS6.
                  • 6. Re: How to duplicate three rectangles at once without grouping?
                    Elwissan Level 1
                    Until then I think the best way is:
                    1. List the layers of each selected item.
                    2. Group selected objects.
                    3. Move to the second document.
                    4. Ungroup them.
                    5. Move each item to its respective layer.
                    I not tried it yet because I was looking for a better way.
                    I just hope that the objects remain in the order. Because it may have the same label.
                    Of course, it will check if the "Paste Remembers Layers" can help.
                    I will trying other forms until exhausted.
                    Elvis
                    • 7. Re: How to duplicate three rectangles at once without grouping?
                      Jump_Over Level 5
                      How it works on your side?
                      var
                        cObj = app.selection[0],
                        sourceIdx = cObj.parentPage.parent.index,
                        targetDoc = app.documents[1],
                        targetSpread = targetDoc.spreads[sourceIdx];
                        cObj.duplicate(targetSpread);
                      Assumings:
                      • 2 doc opened
                      • both have the same page structure (not necessary the same layers)
                      • object to be duplicated - is selected
                      Is destination layer created and object duplicated correctly?
                      Jarek
                      • 8. Re: How to duplicate three rectangles at once without grouping?
                        Elwissan Level 1
                        It is not just an object that will be duplicated but several.
                        I wrote this question with three sample rectangles to simplify the question.
                        Elvis
                        • 9. Re: How to duplicate three rectangles at once without grouping?
                          Elwissan Level 1
                          I tried other ways but always appears a problem.
                          This is the result
                          I wrote that way not to have problems positioning objects between them and their layers.
                          Example using three labels:
                          var findLabels = new Array("Name","Photo","Company");
                          var joinLb = findLabels.join();
                          var result = myAttempt_18 (joinLb);
                          alert("Duplicate objects: " + result);
                          function myAttempt_18(joinLabels){
                              var resultLength = 0;
                              var sourceObj;
                              var destDoc = app.documents[1];
                              var destpage = destDoc.pages[0];
                              var destSameLayer = new Array();
                              var destArrayObjs = new Array();
                              var duplicateObj;
                              with (sourceDoc.pages[0]){
                                  for (var h = pageItems.length-1; h >= 0; h --){
                                      sourceObj = pageItems[h];
                                      if (sourceObj.label != ""){
                                          if (joinLabels.indexOf(sourceObj.label) > -1 ){
                                            duplicateObj =  sourceObj.duplicate(destpage);
                                            destArrayObjs.push(duplicateObj);
                                            destSameLayer.push(sourceObj.itemLayer.name);
                              if (destArrayObjs.length > 0 ){
                                  resultLength = destArrayObjs.length;
                                  destDoc.select(destArrayObjs, SelectionOptions.replaceWith);
                                  destGroup = destDoc.groups.add(destDoc.selection);
                                  destGroup.move ([0,0]);
                                  destDoc.select (destDoc.selection, SelectionOptions.removeFrom);
                                  destGroup.ungroup();
                                  for (var L = 0; L < destArrayObjs.length; L ++){
                                      destArrayObjs[L].move (destDoc.layers.item(destSameLayer[L]));
                                return resultLength;
                          This script will be part of another larger script.
                          The code is not beautiful, but you can use.
                          Link of the document that I tested. (www.wetransfer.com)
                          http://we.tl/6gpfa3zC2W
                          Elvis
                          • 10. Re: How to duplicate three rectangles at once without grouping?
                            Elwissan Level 1
                            I'll leave as a correct answer.
                            I do not know if there's another way better.
                            Elvis
                            • 11. Re: How to duplicate three rectangles at once without grouping?
                              Jump_Over Level 5
                              I wrote this sample of code to simplify the answer
                              Jarek
                              • 12. Re: How to duplicate three rectangles at once without grouping?
                                Elwissan Level 1
                                Hi Mikie9
                                Sorry I have not answered before.
                                Your answer helped me a lot.
                                Thank you.
