1 Reply Latest reply on Jan 13, 2016 9:45 PM by puneeta23771395
    CC Login - Trial is up but I have a [Team] subscription
    ritamkand
      I have CC through work (teams membership) and I'm trying to sign in on my personal laptop to work from home, but it says my trial is up, and there isn't a subscription associated with my ID. What's going on? I've signed in and back out multiple times
        • 1. Re: CC Login - Trial is up but I have a subscription
          puneeta23771395 Adobe Employee
          Please perform following steps depending on your Operating system to fix this issue.
          Activation issue Mac
          1) Close all adobe related processes in activity monitor (Creative cloud, Core sync, CC library, services for adobe desktop app, adobe desktop service, Adobe IPC broker, AAM updater)
          2) Navigate to following locations and assign the current user full permissions to adobe folders. To navigate click go from menu bar at then click goto.. type /Library/application support/   and click go.
          3) To assign the permission right click on adobe folder and click Get info.. A property window will open. Then click on lock symbol to enable editing. Then click + sign to add your username. Then change read only to read and write. Then click gear symbol at the bottom and click apply to enclosed items and click ok.. Proceed to next step then.
          3) Navigate to following location /Library/application support/adobe and Delete Slstore and slcache .
          4) Navigate to ~/Library/application support /adobe/oobe and delete opm.db
          5)Navigate to /etc and open hosts file. Check if it has adobe entries . If no its fine, if yes replace the hosts file with a new hosts file with no adobe entries
          6) Launch cc app and it should work fine
          Activation issue windows
          1) Close all adobe related processes in task manager (Core sync, services for adobe desktop app, adobe desktop service, Adobe IPC broker, AAM updater)
          2) Navigate to following locations and assign the current user full permissions to adobe folders.  (Right click on adobe folder select properties then click security tab , click edit and select current user you are signed in with , select full control , click apply and then ok)
              C://program data (enable view hidden files to see this folder)
              C://program files 86x/common files
              C://program files/common files
              C: //program files/
          3) rename SLstore to Slstore.old at following location c://program data/Adobe/
          4) Rename SLcache to Slcache.old at following location C:\Program Files (x86)\Common Files\Adobe
          4) Navigate to c://users/username/appdata/local/adobe/oobe  and rename Opm.db to opm.old
          5) Navigate to c://windows/system32/drivers/etc/   and open hosts file using notepad. IF you see any Adobe entry there please replace that hosts file with a new hosts file which does not have any adobe entry. If there is no Adobe entry leave the hosts file as it is.
          6) Launch cc app and sign in .
