2 Replies Latest reply on Jun 14, 2016 6:33 AM by joet082964
    Export single page PDF with an InDesign Data Merge
    DaniellaDN
      Hello All!
      This has been driving me crazy! I'm doing a data merge on InDesign CS6, I am creating certificates and am importing the names from a CSV file. But now I need to save each page as individual PDf documents with the file names corresponding to the name on the certificate.
      I've seen threads about running a script that will export the InDesign pages and name the files to an allocated column in the CSV file, in my case is "NAME" I would also like the text "certificate" afterwards if possible.
      The Indesign files has 100+ certificates that I need to separate out and I don't fancy going through them all and renaming each file (I know I can separate out the files in Acrobat Reader)
      I did try a script below:
      var CSV = function(data) {
          var _data = data.split('\r\n');
          for(var i in _data) {
              if(_data[i].length > 0) {
                  console.println(i + ' ' + _data[i]);
                  _data[i] = _data[i].split(',');
          var _head = _data.shift();
          return {
              length: function() {
                  return _data.length - 1;
              getRow: function(row) {
                  return _data[row];
              getRowAndColumn: function(row, col) {
                  if(typeof col !== 'string') {
                      return _data[row][col];
                  } else {
                      col = col.toLowerCase();
                      for(var i in _head) {
                          if(_head[i].toLowerCase() === col) {
                              return _data[row][i];
      this.importDataObject("CSV Data");
      var dataObject = this.getDataObjectContents("CSV Data");
      var csvData = new CSV(util.stringFromStream(dataObject));
      if(this.numPages != csvData.length()) {
          app.alert("Number of pages & CSV row count inconsistent");
      } else {
          for(var i = 0; i < this.numPages; i++) {
              this.extractPages({nStart: i, cPath: csvData.getRowAndColumn(i, 'NAME') + '.pdf'});
      but got the message : this.importDataObject is not a function
      Thank you in advance!
