4 Replies Latest reply on Jan 18, 2016 8:43 AM by sue_k
    what is wrong with my calculate script?
    sue_k
      I have a form within a document and can't figure out what is wrong.
      The debugger error:
      TypeError: getField(...) is null
      10:Field:Calculate
      37:AcroForm:G.44:Calculate
      The (calculate) code in column 10 is:
      (function () {
         // Get the field values, as numbers
         var A0 = +getField("A.0").value;
         var B0 = +getField("B.0").value;
         var C0 = +getField("C.0").value;
         var D0 = +getField("D.0").value;
         var E0 = +getField("E.0").value;
         var F0 = +getField("F.0").value;
         var G0 = +getField("G.0").value;
         var H0 = +getField("H.0").value;
         // Set this field’s value to the sum
         event.value = A0 + B0 + C0 + D0 + E0 + F0 + G0 + H0 ;
      There are 10 columns that add horizontally. (Column 9 is actually empty and not used, if that makes a difference)
      And 44 rows that add vertically.
      The error message multiples as I progress in the form/matrix, but regularly references the same "10" and "37", but the "G.44" is sometimes "M.44".
      I keep staring and can't find the error.
        • 1. Re: what is wrong with my calculate script?
          That error message means you're trying to access a field name which doesn't
          exist.
          • 2. Re: what is wrong with my calculate script?
            There is a way to trap the field name of the problem field or fields by writing a function that takes as input the field name and returns the field object or a null object and if the field name supplied does not match with a field object it alerts the user to the error.
            function GetField(cName) {
            var oField = this. getField(cName);
            if(oField == null) {
            app.alert("Error accessing field named " + cName, 1, 0);
            return oField;
            } // end GetField function;
            (function () {
               var oA0 = GetField("A.0");
               var oB0 = GetField("B.0");
               var oC0 = GetField("C.0");
               var oD0 = GetField("D.0");
               var oE0 = GetField("E.0");
               var oF0 = GetField("F.0");
               var oG0 = GetField("G.0");
               var oH0 = etField("H.0");
            g
               event.value = +oA0.value + =oB0.value + oC0.value + +oD0.value + oE0.value + +oF0.value + +oG0.value + oH0.value ;
            I try to stay away from self defining functions until the form has been debugged since this type of function sometimes hides the full error message.
            Also I probably would have written a defined function to sum a the values of an array of field names so I could reuse the function to sum any given series of field names.
            • 3. Re: what is wrong with my calculate script?
              sue_k Level 1
              Thanks!
              Finally found the two errors!
              • 4. Re: what is wrong with my calculate script?
                sue_k Level 1
                Thank you for your time on this!
                So appreciate you all in the forums!
