2 Replies Latest reply on Jan 14, 2016 9:24 PM by Rick Gerard
    Creating karaoke video with text
      I'm just starting out and I wanted to start a new project where I create a karaoke video.
      I'm doing a line of text at a time and I figured out how to highlight each word as the song plays.
      I am wondering how I transition to the next line or set of text.  For instance, if I write "Jingle Bells, Jingle Bells" how do I then have this text disappear and the next line appear?  Would each line be a separate layer?
        • 1. Re: Creating karaoke video with text
          Dave LaRonde Level 6
          Yup.  You do the karaoke version of Bach's Mass In B Minor and you're talkin' a whole boatload of layers.
          • 2. Re: Creating karaoke video with text
            This is about a zillion times easier and faster to do in Premiere Pro with simple animated titles. It's far easier to do longer projects like this in a NLE.
            If you insist on doing everything in After Effects then you're going to end up with a separate layer for each line of lyrics that you want to animate across the screen. There are ways to analyze a voice over track in Premiere Pro and extract the words, then put those words on markers in an audio file and import that file into AE to help you with the timing, but it's still going to be easier in Premere Pro.
            Here's what I would do. Watch this tutorial on creating a Live Text Template in After Effects to use in Premiere Pro. How to use Live Text templates from After Effects in Premiere Pro | Adobe Premiere Pro CC tutorials
            Back in AE build a template long enough for your longest phrase and set some place holder type
            Open the Advanced tab in the Composition Settings and check the box that says Editable In Premiere Pro
            Save the AE project and import it into Premiere Pro
            As you drop each new phrase into Premiere Pro adjust the timing of the words buy using the time stretch tool in the Sequence Timeline
            That's about it.
            If you want three or four styles of fade in and out then make 3 or 4 template comps.
            If you stay inside AE just start adding text layers, text animators and key framing all of the words by hand. Creating some animation presets may help but the first suggestion will be the quickest.
