3 Replies Latest reply: May 31, 2009 5:13 PM by lucaslemonnier RSS
    Pasting images into Dreamweaver
    mikeklar Community Member
      Dreamweaver CS4 does not allow an image copied from Photoshop CS4 to be pasted, i.e. after copying an image in Photoshop then clicking on Edit in DW the "Paste" is grayed out and Nada...
      Anyone having a similar issue?
      Cheers
      Michael
        • 1. Re: Pasting images into Dreamweaver
          Stuart Haiz Community Member
          No problem here. Are both apps already open before you copy? If they are, this is what should happen - in PS select all & either copy your current layer or Cmd + Shift + A to copy all layers. Switch to DW & hit Cmd + V or use the menus, Edit > Paste. If it is grayed out you most likely have no content to paste. However, the copy all in PS should have got round that one.
          If you do mange to paste, you should get the optimise dialog box followed by a prompt to save your file as...
          If this is not working for you, perhaps a reboot of your system might fix it.
          • 2. Re: Pasting images into Dreamweaver
            Sirius 7
            Thank you for responding.
            Yes, I've done all the things you noted, but to no avail.
            Rebooting and reloading all files do not remedy the problem.
            The only way is to go through the "Select Image Source". That's a pain if all one wants is a selction of a portion of an image, which means cropping in PS and saving it separately.
            As well this method does not open the "optimise dialog" box.
            Strange...
            Cheers,
            Michael
            • 3. Re: Pasting images into Dreamweaver
              lucaslemonnier
              Hello Michael,
              Having the same exact issue here. Have you managed to find a solution?
              Thanks, Lucas
