1 Reply Latest reply on Jan 28, 2009 2:15 AM by SujitG
    Trying to figure out this error
    Reevesp
      I have a Flex website that I created and I'm getting the following error when I try to call to my ColdFusion RemoteObjects:
      [RPC Fault faultString="Send failed" faultCode="Client.Error.MessageSend" faultDetail="Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Failed: url: ' http://reevespro.com/flex2gateway/'"
      I haven't a clue where or to fix. And I have no idea why it's trying to call flex2gateway, the directory doesn't exist. Anyone have a clue?
        • 1. Re: Trying to figure out this error
          SujitG Level 2
          If you are using the ColdFusion adapter for BlazeDS/LCDS, please open remoting-config.xml and see which channel your Remoting destination is using. In services-config.xml, you should be able to find channel used above configured. You should be modifying the end point URL of the channel.
          Hope this helps.
