4 Replies Latest reply on Jan 18, 2016 1:55 PM by Schmaltzkopf
    How do I add a ME textbox?
    Schmaltzkopf
      Hi, there.
      I am using ID ME. When I use the UI, I have the option of creating a standard text-frame by using the Type tool,
      and the option of creating a "ME text-frame" by using the ME Type tool.
      How can I script a ME text=frame?
      I understand that I can script a regular text-frame, and then change the paragraph direction, etc. but I figure, if there is a shorter way...
      Thank you.
        • 1. Re: How do I add a ME textbox?
          TᴀW Adobe Community Professional & MVP
          I don't think there is any such thing as an ME text frame. It's just a UI convenience that, as you say, creates a text frame, assigns a RTL paragraph direction, and assigns an RTL story direction.
          • 2. Re: How do I add a ME textbox?
            Trevorׅ Adobe Community Professional
            Hi S,
            Ariel  is right there's no such thing as a ME text frame.
            If anything there's a ME story.
            var meStoryProps = {
                paragraphDirection: ParagraphDirectionOptions.RIGHT_TO_LEFT_DIRECTION,
                characterDirection: CharacterDirectionOptions.RIGHT_TO_LEFT_DIRECTION,
                keyboardDirection: CharacterDirectionOptions.RIGHT_TO_LEFT_DIRECTION
            var doc = app.properties.activeDocument || app.documents.add();
            // add "ME" textFrame to 1st page of Doc
            var meTextFrame = doc.pages[0].textFrames.add({geometricBounds: ["10mm", "10mm", "100mm","100mm"]});
            meTextFrame.parentStory.properties = meStoryProps;
            If you have a few ME stories to setup you can just store the properties and then assign them to the frames parentStory
            HTH
            Trevor
            • 3. Re: How do I add a ME textbox?
              Hm, I assumed in an ME version it depends on the preferences, if you add a new text frame, that this frame has RTL directions.
              Also the binding option, etc.pp.
              As defined in:
              app.documentPreferences.pageBinding   PageBindingOptions.RIGHT_TO_LEFT
              app.textDefaults.characterDirection   CharacterDirectionOptions.RIGHT_TO_LEFT_DIRECTION
              app.textDefaults.composer
              app.textDefaults.digitsType
              app.textDefaults.kashidas
              app.textDefaults.keyboardDirection
              app.textDefaults.paragraphDirection
              app.textDefaults.paragraphJustification
              app.textDefaults.paragraphKashidaWidth
              app.storyPreferences.storyDirection   StoryDirectionOptions.RIGHT_TO_LEFT_DIRECTION
              Could be, that I missed some…
              You can look up all these here:
              http://www.jongware.com/idjshelp.html
              InDesign ExtendScript API (10.0)
              InDesign ExtendScript API (11.0)
              Uwe
              • 4. Re: How do I add a ME textbox?
                Schmaltzkopf Level 1
                Thank you Trevor. The link to ME scripting guide that you sent me had the "meat-and-potatoes" for what you said (and for what Laubender said), but I appreciate that you put it into the story properties.
                Thank you again,
                All the best
