8 Replies Latest reply on Jan 18, 2016 8:27 PM by tpk1982
    Dialog VS Palette (Palette not support)
    BEGINNER_X Level 3
      Hi All,
      While using       "var w = new Window ("dialog")", working & display like a charm
      If I am using,     "var w = new Window ("palette"); UI comes and hide
      Tried Indesign version CS6 & CC2014.
      Below is the DIALOG coding, working like a charm.
      Suppose, If change dialog into palette, UI not working properly.
      Please help.
      var myDocFullPath = app.activeDocument.fullName;
      myDocFullPath = myDocFullPath + "";
      //-------------------------------------START UI1--------------------------------------
          var myCount_UI = 0;
          var clickcancel = 0;
          var w = new Window ("dialog");
          var myGroup1 = w.add('panel', undefined, 'RRRRR');
          myGroup1.alignChildren = "left";
          var versions = ["--", "V1", "V2", "V3", "V4", "V5"];
          var main = myGroup1.add ('panel {orientation: "row"}');
          var group = main.add ("group {alignChildren: 'left', orientation: 'row'}");
          group.add ("statictext", undefined, "Job Version*         : ");
          var list5 = group.add ("dropdownlist", [0,0,100,20], versions);
          list5.minimumSize.width = 250;
          list5.selection = 0;
           var Oper_Name = ["--",         "XXX", "YYY"];
          group.add ("statictext", undefined, "Operator Name*    : ");
          var list4 = group.add ("dropdownlist", [0,0,250,20], Oper_Name);
          list4.minimumSize.width = 250;
          list4.selection = 0;
          //Button Concept Here
          var myButtons = w.add ("group");
          var EXPORT = myButtons.add("button", undefined, "GoTo CheckList", {name: "ok"});
          var CAN = myButtons.add("button", undefined, "Cancel", {name: "exit"});
           EXPORT.onClick = function () {
              if(list5.selection.index == 0) {
               alert("PLEASE SELECT INDESIGN VERSIONS ");
              else{
                      w.close();
          CAN.onClick = function (){
                  clickcancel = 1;
                  w.close();
          w.show();
          if(clickcancel == 1){
                  //this.exit();
                 exit();
      //---------------------------------------------END OF UI1-----------------------------------
      //---------------------------------------------START OF UI2-----------------------------------
      if(myDocFullPath.indexOf("/PROCTER_AND_GAMBLE/") >= 0)
          var myRegion = "AAA";
                  w.alignChildren = "left";
                  var myGroup1 = w.add('panel', undefined, 'TTTTTT');
                  var checkbox1 = myGroup1.add ("checkbox", undefined, "01.  Check the ratio, artwork & live area sizes against job ticket and slug information");
                  var checkbox2 = myGroup1.add ("checkbox", undefined, "02.  Check images are linked");
                  var EXPORT = myButtons.add("button", undefined, "Export PDF", {name: "ok"});
                       w.close(); }
                      clickcancel = 1;
                      w.close();}
          w.show();
                          //this.exit();
                         exit();
        • 1. Re: Dialog VS Palette (Palette not support)
          tpk1982 Level 4
          Hi Siraj,
          A dialog window does wait for show() to complete. A palette window does not wait for show() to complete.
          Add "#targetengine "session" at the beginning of your script ...
          or
          Use $.sleep()
          Karthi
          • 2. Re: Dialog VS Palette (Palette not support)
            BEGINNER_X Level 3
            I tried "#targetengine "session"" in the beginning of script, even though not working.
            See the above script, in my code two UI is using.
            Thanks in advance
            Siraj
            • 3. Re: Dialog VS Palette (Palette not support)
              tpk1982 Level 4
              Really?? Here its working fine..
              okay
              Use $.sleep() then
              • 4. Re: Dialog VS Palette (Palette not support)
                tpk1982 Level 4
                change both in line 10 and 79 to "palette"
                • 5. Re: Dialog VS Palette (Palette not support)
                  BEGINNER_X Level 3
                  Any help, Still not working...
                  If anyone test in your end,
                  1. copy and Paste the provided script (dialog) and run the script ------ Two UI will Shown
                  2. Replace Dialog into Palette (2 occurrences) and run the script ---- One UI will shown
                  Any clarification, please test and revert.
                  • 6. Re: Dialog VS Palette (Palette not support)
                    tpk1982 Level 4
                    even with "dialog".. no 2 UI shown!!!
                    we need to have /PROCTER_AND_GAMBLE/ folder? be specfic
                    • 7. Re: Dialog VS Palette (Palette not support)
                      BEGINNER_X Level 3
                      Hi All,
                      Please help to solve this bug or issues.
                      Karthi: Place Indesign File inside the "PROCTER_AND_GAMBLE" Folder.
                      • 8. Re: Dialog VS Palette (Palette not support)
                        tpk1982 Level 4
                        Hi SIraj,
                        I just add those 2 UI as functions and it is working fine.. pls use the below code:
                        #targetengine "siraj"
                        myui1();
                        function myui1()
                            var myCount_UI = 0;
                                else{
                                        w.close();
                                myui2();
                                    clickcancel = 1;
                                    w.close();
                            w.show();
                                    //this.exit();
                                  exit();
                          function myui2()
                                        w.close(); }
                                        clickcancel = 1;
                                        w.close();}
                            w.show();
                                            //this.exit();
                                          exit();
