3 Replies Latest reply on Jan 28, 2009 11:28 AM by josenspencernbubu
    Unable to connect to SQL 2005 Express Database
    josenspencernbubu
      I am new to Flex and i am trying to use the Create application from Database wizard and I am not able to connect to any of my MS SQL or PostgreSQL servers. I keep getting this error:
      java.sql.SQLException: Unknown server host name '10.40.213.80\SQLEXPRESS'.
      at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:364)
      at net.sourceforge.jtds.jdbc.ConnectionJDBC3.<init>(ConnectionJDBC3.java:50)
      at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:178)
      at org.eclipse.datatools.connectivity.db.generic.JDBCConnection.createConnection(JDBCConnect ion.java:87)
      at org.eclipse.datatools.connectivity.DriverConnectionBase.internalCreateConnection(DriverCo nnectionBase.java:104)
      at org.eclipse.datatools.connectivity.DriverConnectionBase.open(DriverConnectionBase.java:53 )
      at org.eclipse.datatools.connectivity.db.generic.JDBCConnectionFactory.createConnection(JDBC ConnectionFactory.java:52)
      at org.eclipse.datatools.connectivity.internal.ConnectionFactoryProvider.createConnection(Co nnectionFactoryProvider.java:77)
      at org.eclipse.datatools.connectivity.internal.ConnectionProfile.createConnection(Connection Profile.java:354)
      at com.adobe.datatools.derived.wizards.BaseConnectionProfilePage.testConnectionSimple(BaseCo nnectionProfilePage.java:70)
      at com.adobe.datatools.derived.wizards.BaseConnectionProfilePage.testConnection(BaseConnecti onProfilePage.java:51)
      at org.eclipse.datatools.connectivity.ui.wizards.ConnectionProfileDetailsPage$1.widgetSelect ed(ConnectionProfileDetailsPage.java:85)
      at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:227)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3682)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3293)
      at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
      at org.eclipse.jface.window.Window.open(Window.java:796)
      at com.adobe.flexbuilder.dbwizard.ui.DbWizard$8.widgetSelected(DbWizard.java:598)
      at com.adobe.flexbuilder.dbwizard.actions.DBWizardAction.run(DBWizardAction.java:69)
      at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:256)
      at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
      at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:546)
      at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:490)
      at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :402)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2389)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
      at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :112)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
      at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
      Caused by: java.net.UnknownHostException: 10.40.213.80\SQLEXPRESS
      at java.net.PlainSocketImpl.connect(Unknown Source)
      at java.net.SocksSocketImpl.connect(Unknown Source)
      at java.net.Socket.connect(Unknown Source)
      at net.sourceforge.jtds.jdbc.SharedSocket.createSocketForJDBC3(SharedSocket.java:289)
      at net.sourceforge.jtds.jdbc.SharedSocket.<init>(SharedSocket.java:250)
      at net.sourceforge.jtds.jdbc.ConnectionJDBC2.<init>(ConnectionJDBC2.java:297)
      ... 57 more
      I have enabled both remote and local connections on my servers, I can connect to them using DSN connections in Windows and from other web development apps such as MS visual studio. Is there any special configuration that flex requires?
