2 Replies Latest reply on Jan 28, 2009 4:20 PM by budzilla1
    cfajaxproxy hangs
    budzilla1
      I'm having trouble getting cfajaxproxy to return the result from my function. I can call the function and get a response when I use <cfinvoke>, but when I use cfajaxproxy the function hangs at the <cfreturn> statement. Here's my function code:
      <cffunction
      name="hoser"
      access="remote"
      returntype="string">
      <cfset myReturnFoo = "foo">
      <!--- code hangs here when called by cfajaxproxy--->
      <cfreturn myReturnFoo>
      </cffunction>
      And here's how I'm calling it:
      <cfajaxproxy cfc="idiot" jsclassname="idiot_proxy" />
      function getHoser() {
      var instance = new idiot_proxy();
      instance.setErrorHandler(getHoserFailure);
      instance.setCallbackHandler(getHoserSuccess);
      instance.hoser();
      function getHoserSuccess(result) {
      alert("In getHoserSuccess");
      alert(result);
      function init() {
      getHoser();
      Any help would be greatly appreciated.
        • 1. Re: cfajaxproxy hangs
          Level 7
          1) when using cf ajax features, one must declare in-page js functions as
          functionName = function() {
          and NOT as
          function functionName() {
          2) you MUST have getHoserFailure js function defined in your script - do
          you have it and just didn't post it?
          3) in cf admin, enable ajax debugger, then add ?cfdebug to your URL to
          see the pop-up ajax debugger window - it may very well give you more
          info about any errors occurring with your cfajaxproxy.
          4) VAR you variables inside cfc functions! use <cfset var MyReturnFoo =
          "foo">. but in a simple test function like yours you do not even need to
          set the variable - you can just do <cfreturn "foo">
          Azadi Saryev
          Sabai-dee.com
          http://www.sabai-dee.com/
          • 2. Re: cfajaxproxy hangs
            budzilla1 Level 1
            Thanks Azadi. Unfortunately, none of your suggestions bore fruit. I do have the failure handler script defined, but just didn't post it. I had my web server admin enable Ajax debugging, but I don't see any pop-up window that gives me any error messages. I'm using firebug, and the only message I get is "Remote CFC timed out while waiting to execute."
            The strange thing is that I had some fairly intensive data exchanges working two weeks ago when I last looked at it. Now, I can't even pass a string back. :(
