3 Replies Latest reply on Jan 19, 2016 12:11 PM by Stephen_A_Marsh
    How do I pull pages Im working on and save them to a separate folder?
    josephp9851989
      I'm producing a lot of pages with PDF's in them and the programs starting to slow down. I need to organise these pages into separate documents, how do I do that?
        • 1. Re: How do I pull pages Im working on and save them to a separate folder?
          Save with a new name and delete those pages you will not need in that document.
          • 2. Re: How do I pull pages Im working on and save them to a separate folder?
            You could speed things up by changing the overall Display Performance setting, or changing it for individual, complex PDFs. Check Allow Object-Level Display Settings under View>Display Performance, and then select a PDF and choose Fast or Typical Display under Object>Display Performance.
            Also you are linking and not embedding the PDFs?
            • 3. Re: How do I pull pages Im working on and save them to a separate folder?
              Stephen_A_Marsh Adobe Community Professional
              Try this (or if you use CS6 try the following script after this one):
              //**** Page extractor 1.0 - A script from Loïc Aigon with the great help of Peter Kahrel and other guys
              //**** that cooperated on this stuff in tha adobe scripting forum. Feel free to improve.
              //**** a little mail at loic _ aigon@yahoo.fr if you appreciate that script would be nice.
              // <L10N> :: FRENCH_LOCALE :: RUSSIAN_LOCALE
              // Please save you file first before processing the script :: Enregistrez votre document avant de lancer le script :: Пожалуйста сохраните документ перед запуском скрипта
              // Extract pages... :: Extraire des pages... :: Извлечь страницы...
              // to :: a :: по
              // Extract as separate pages :: Extraire chaque page comme un fichier :: Извлечь как отдельные страницы
              // Remove pages after extraction :: Supprimer les pages après extraction :: Удалить страницы после извлечения
              // Choose other extraction folder :: Choisir un autre dossier d'extraction :: Выбрать папку для сохранения
              // </L10N> ::
              // 2. Add the code's block below in your script:
              if ( typeof __ == 'undefined' )
              __sep = ' :: ';
              __beg = ' <L10N>';
              __end = ' </L10N>';
              /*arr*/File.prototype.getCommentsContaining = function(/*str*/k_)
                var r = [];
                if ( this.open('r') )
                var line;
                while(!this.eof)
                line = this.readln();
                if ( ( line.substr(0,2) == '//' )
                && ( line.indexOf(k_) >= 0 ) )
                r.push(line.substr(2));
                this.close();
                return(r);
              /*arr*/Array.prototype.parseL10N = function(/*str*/locale_)
                var r = [];
                var sz = this.length;
                var lm, ss;
                var st = -1
                var rg = 0;
                for ( var i=0 ; i < sz ; i++ )
                ss = this[i].split(__sep, lm);
                if ( ( st == -1 ) && ( ss[0] == __beg ) )
                lm = ss.length;
                for ( var j = 1 ; j < lm ; j++ )
                if ( ss[j] == locale_ ) rg=j;
                st = 0;
                continue;
                if ( st == 0 )
                if ( ( rg == 0 ) || ( ss[0] == __end ) ) break;
                if ( ss.length <= rg ) continue;
                r[ss[0].substr(1)] = ss[rg];
                return(r);
              /*str*/Number.prototype.toLocaleName = function()
              for ( var p in Locale )
                if ( Locale[p] == this ) return(p);
              return(null);
              String.L10N = File(app.activeScript).
                getCommentsContaining(__sep).
                parseL10N(app.locale.toLocaleName());
              function __(s){return(String.L10N[s]||s);}
              // 1. Control for documents open. If true, the script launches the dialog
              if(app.documents.length >0)
                var doc = app.activeDocument;
                if(doc.saved==true)
                extractdlg();
                else
                alert(__("Please save you file first before processing the script"));
              else
                alert("No documents open !");
              // 2. Gathers many infos on the document.
              function pageinfos()
                var pg = doc.pages;
                var pglg  = pg.length;
                var pFirst = Number(pg[0].name);
                var pLast = Number(pg[pglg-1].name);
                var pgHeigth = doc.documentPreferences.pageHeight;
                var pgWitdh = doc.documentPreferences.pageWidth;
                var docname = String(doc.fullName).replace (/\.indd$/, "");
                var docpath = doc.filePath;
                var docfullname = doc.fullName;
                var infoarr = [pglg, pFirst, pLast, pgHeigth,pgWitdh,docname,docpath,docfullname];
                return infoarr;
              // 3. Main function. First part is the dialog
              function extractdlg()
                var docfile = String(pageinfos()[7]);
                var dlg = app.dialogs.add({name : "Pages Extractor 1.0 - ©www.loicaigon.com"});
                with(dlg)
                var firstclmn = dialogColumns.add();
                with(firstclmn)
                var firstrow = dialogRows.add();
                with(firstrow)
                var clmn1 = dialogColumns.add();
                with(clmn1)
                var row1 = dialogRows.add();
                row1.staticTexts.add({staticLabel : __("Extract pages...")});
                var row2 = dialogRows.add();
                with(row2)
                var r2c2 = dialogColumns.add();
                with(r2c2)
                var r2c2r1 = dialogRows.add();
                var pgStart = r2c2r1.realEditboxes.add({editValue:pageinfos()[1], minWidth: 30});
                var r2c3 = dialogColumns.add();
                with(r2c3)
                var r2c3r1 = dialogRows.add();
                r2c3r1.staticTexts.add({staticLabel : __("to")});
                var r2c4 = dialogColumns.add();
                with(r2c4)
                var r2c4r1 = r2c4.dialogRows.add();
                var pgEnd = r2c4r1.realEditboxes.add({editValue:pageinfos()[2], minWidth: 30});
                var secondrow = dialogRows.add();
                with(secondrow)
                var clmn2 = dialogColumns.add();
                with(clmn2)
                with(row2)
                var sepbox = checkboxControls.add({staticLabel:__("Extract as separate pages"), checkedState:false});
                var thirdrow = dialogRows.add();
                with(thirdrow)
                var clmn3 = dialogColumns.add();
                with(clmn3)
                var row3 = dialogRows.add();
                with(row3)
                var rembox = checkboxControls.add({staticLabel:__("Remove pages after extraction"), checkedState:false});
                var foutrhrow = dialogRows.add();
                with(foutrhrow)
                var clmn4 = dialogColumns.add();
                with(clmn4)
                var row4 = dialogRows.add();
                with(row4)
                var savebox = checkboxControls.add({staticLabel:__("Choose other extraction folder"), checkedState:false});
                // If the user made good choices, the script operates.
                if(dlg.show()==true)
                if(pgStart.editValue >= pageinfos()[2] || pgEnd.editValue <= pageinfos()[1])
                alert("The pages numbers may be at least "+pageinfos()[1] +" for the first page of the range and "+ pageinfos()[2] + " at maximum for the last page");
                else
                // If the user choose to pick a different folder, he will be asked for. Otherwise, the dafault folder is the one containing the file.
                if(savebox.checkedState==true)
                var extractfolder = Folder.selectDialog ("Please choose a folder where to save extracted pages...");
                if(!extractfolder)
                exit();
                else
                var saveextractfolder = String(extractfolder.fullName)+"/" +String(doc.name).replace (/\.indd/, "");
                else
                var saveextractfolder = String(pageinfos()[5]);
                var rem0 = pageinfos()[0]-1;
                var rem2 =  (pgStart.editValue-2);
                // Variables definition regarding to the choice of the user to separate or not the extracted pages.
                if(sepbox.checkedState==true)
                var W = pgEnd.editValue-pgStart.editValue+1;
                var rem1 = pgStart.editValue;
                else
                var W = 1;
                var rem1 = pgEnd.editValue;
                // Extraction loop
                for(w=0; w<W;w++)
                var exportdocname = "_Pg" +(pgStart.editValue+w) +".indd";
                else
                var exportdocname = "_Pg"+pgStart.editValue+"_to_Pg_"+pgEnd.editValue +".indd";
                for(var i=rem0; i>=rem1+w;i--)
                doc.pages[i].remove();
                for(var i=rem2+w; i>=0;i--)
                var exportdoc = doc.save(File(saveextractfolder + exportdocname));
                exportdoc.close(SaveOptions.no);
                if(sepbox.checkedState==true && w<(pgEnd.editValue-pgStart.editValue))
                app.open(File(docfile));
                // If the user chose to remove the extracted pages from the original document, it will re open the first document then remove the unuseful pages.
                if(rembox.checkedState == true)
                for(var i=pgEnd.editValue-1; i>=pgStart.editValue-1;i--)
                app.activeDocument.close(SaveOptions.yes);
              Or this version for CS6:
                var doc = app.documents[0];
                if(doc.saved==true)
                extractdlg();
                else
                alert("Please save you file first before processing the script");
              else
                var pg = doc.pages;
                var docname = String(doc.fullName).replace(/\.indd$/, "");
                return infoarr;
                var dlg = app.dialogs.add({name : "Pages Extractor 1.1 - ©www.loicaigon.com"});
                with(dlg)
                with(firstclmn)
                with(firstrow)
                with(clmn1)
                row1.staticTexts.add({staticLabel : "Extract pages..."});
                with(row2)
                with(r2c2)
                with(r2c3)
                r2c3r1.staticTexts.add({staticLabel : "to"});
                with(r2c4)
                with(secondrow)
                with(clmn2)
                with(row2)
                var sepbox = checkboxControls.add({staticLabel: "Extract as separate pages", checkedState:false});
                with(thirdrow)
                with(clmn3)
                with(row3)
                var rembox = checkboxControls.add({staticLabel: "Remove pages after extraction", checkedState:false});
                with(foutrhrow)
                with(clmn4)
                with(row4)
                var savebox = checkboxControls.add({staticLabel: "Choose other extraction folder", checkedState:false});
                else
                if(!extractfolder)
                exit();
                else
                else
                else
                var W = 1;
                // Extraction loop
                for(w=0; w<W;w++)
                else
              Hope this helps!
