• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
when using Presenter 11 with Powerpoint 2013, the dialog boxes are so small, they're unreadable
New Here ,
Jan 19, 2016 Jan 19, 2016
I have a Microsoft Surface Pro 4, with a Windows 10 operating system.  I'm working in PowerPoint 2013 - the dialog boxes that pop-up are SO small that the text is barely readable.  The size of the PowerPoint slide I'm viewing is fine -- it's only the dialog boxes that are minuscule.  Is there some setting I can change to make the dialog box size (and text) larger?  I don't need to make everything larger -- just the dialog boxes and the text inside them.
I already checked with Microsoft -- and since it just seems to be a problem with Adobe, they said its not their issue.   http://answers.microsoft.com/en-us/office/forum/office_2013_release-powerpoint/dialog-boxes-are-too-...
This also happened when using Microsoft Edge while I was in contact with Adobe support.  See all attached screen shots.  So -- it seems like an issue with Adobe products, not just with Presenter & Powerpoint.  Any suggestions would be greatly appreciated!
TOPICS
Presenter
Views
846
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Jan 20, 2016 Jan 20, 2016
This has come up for using Adobe Connect (and other Adobe products) as well. I believe you can solve this problem as described here: http://www.danantonielli.com/adobe-app-scaling-on-high-dpi-displays-fix/
Votes
Translate
Translate
Report
Report
New Here ,
Jan 21, 2016 Jan 21, 2016
Thank you for the reply.  I tried this, but couldn't get it to work.  I've left a comment on the post you forwarded to me.  Hopefully someone can help me resolve it.
Votes
Translate
Translate
Report
Report
LEGEND ,
Great, let us know if you get it to work.
You may need to create the manifest file to mach the dll file for Presenter. It can be found at C:\Program Files (x86)\Adobe\Adobe Presenter 11\MenuLauncher.dll.
Votes
Translate
Translate
Report
Report
New Here ,
and call the file:  Adobe Presenter 11\MenuLauncher.dll.manifest ?  Save as text file or "all files"
Thanks.
Votes
Translate
Translate
Report
Report
LEGEND ,
Jan 22, 2016 Jan 22, 2016
Since there isn't an exe file for Presenter, that is what I would test first.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 27, 2016 Jan 27, 2016
LATEST
Thanks for the suggestion.  I tried it, but it didn't work either.  I'm going to go through all of the steps again from the beginning and make sure I've done it all right.
Votes
Translate
Translate
Report
Report
Resources
Help resources
