1 Reply Latest reply on Feb 2, 2016 8:24 PM by Carl Von Stetten
    ColdFusion with file geodatabases?
      Does anyone have experience using ColdFusion with file geodatabases?
      Is is possible? Any issues?
        • 1. Re: ColdFusion with file geodatabases?
          Carl Von Stetten Adobe Community Professional & MVP
          Are you referring to Esri ArcGIS file geodatabases?  If so, that is a proprietary database format that is not usually supported outside of GIS software applications.  If you only need to access attribute data with ColdFusion, then I would suggest moving the data into a SQL Server Express database and store the data as either SDEBinary (which still stores attribute data in normal SQL Server data types) or as native SQL Server geometry/geography (which makes all of the data potentially readable by ColdFusion).
