7 Replies Latest reply on Jan 23, 2016 1:53 PM by JJMack
    original file name after making contactsheet.
    adriaanvandam Level 1
      I made 2 photo's of the same coin (front and back). I have to combine them into 1 photo as below. I have to give the coin the name of the first photo. there are 4000 coins so I want to do it in a batch.
      How do I manage it.
      I know how to batch, make a contact sheet. but... to give the file the name of the original file name of one of the coin seems to be very hard.
      Is there a script for this? Can someone help me?
      Thank you! Adriaan.
        • 1. Re: original file name after making contactsheet.
          You could most likely create a Photo Collage Template for my Photo Collage Toolkit.  Then use the script BatchMultiImageCollage.jsx to populate the template with coin images.  The coin file names would need to have a prefix that would cause the coins front and back to sort together any file type can be used..  Note the prefix and type will be stripped from the filename the remaining name stamped on the images.  Images will be sized and positioned for the template.  You would need and even number of image location in you template.
          For example:
          100#Name Head
          100#Name Tail
          101#Name Head
          101#Name Tail
          102#Name Head
          102#Name Tail
          Photoshop scripting is powerful and I believe this package demonstrates this A video showing a 5 image collage PSD template  being populates with images:
          The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
          1. Size the photo collage templates for the print size you want - width, height and print DPI resolution.
          2. Photo collage templates must have a Photoshop background layer. The contents of this layer can be anything.
          3. Photo collage templates must have alpha channels named "Image 1", "Image 2", ... "Image n".
          4. Photo collage templates layers above the background layers must provide transparent areas to let the images that will be placed below them show through.
          There are twelve scripts in this package they provide the following functions:
          1. TestCollageTemplate.jsx - Used to test a Photo Collage Template while you are making it with Photoshop.
          2. CollageTemplateBuilder.jsx - Can build Templates compatible with this toolkit's scripts.
          3. LayerToAlphaChan.jsx - Used to convert a Prototype Image Layer stack into a template document.
          4. InteractivePopulateCollage.jsx - Used to interactively populate Any Photo Collage template. Offers most user control inserting pictures and text.
          5. ReplaceCollageImage.jsx - use to replace a populated collage image Smart Object layer with an other image correctly resized and positioned.
          6. ChangeTextSize.jsx - This script can be used to change Image stamps text size when the size used by the populating did not work well.
          7. PopulateCollageTemplate.jsx - Used to Automatically populate a Photo Collage template and leave the populated copy open in Photoshop.
          8. BatchOneImageCollage.jsx - Used to Automatically Batch Populate Collage templates that only have one image inserted. The Collage or Image may be stamped with text.
          9. BatchMultiImageCollage.jsx - Used to Automatically Batch Populate Any Photo Collage template with images in a source image folder. Easier to use than the interactive script. Saved collages can be tweaked.
          10. BatchPicturePackage.jsx - Used to Automatically Batch Populate Any Photo Collage template with an image in a source image folder
          11. PasteImageRoll.jsx - Paste Images into a document to be print on roll paper.
          12. PCTpreferences.jsx - Edit This File to Customize Collage Populating scripts default setting and add your own Layer styles.
          Documentation and Examples
          • 2. Re: original file name after making contactsheet.
            Hi JJMack,
            Thanks for your explanation! I have Photoshop CC and I get an error message when trying opening the jsx file. Main()  errCode[-35] line[3681] Exception.
            So I'm not sure if its useful.
            • 3. Re: original file name after making contactsheet.
              That message tells me that your not using my script BatchMultiImageCollage.jsx script for it is only 1113 line and the word Main does not exist in that file.
              You need to copy my *.jsx scripts to Photoshop Presets\Scripts\ folder. You run the script from menu File>Scripts>Script Name.
              Place the .jxs files in Photoshop Presets\Scripts Folder
              Drop the .atn files and .asl files onto Photoshop to load the actions and Layer styles
              Unzip CollageTemplates.zip into "C:\Program Files\Adobe\Adobe Photoshop Templates" or any folder you want to keep your collage templates in.
              You will see the scripts listed in Photoshop menu File>Scripts>script name
              Files in zip
              1.) ReadMe.txt
              2.) JJmack's Photo Collage Toolkit Scripts.atn
              3.) SnowGlobe.atn
              4.) Photo Collage Styles.asl
              5.) Photo Collage Text Styles.asl
              6.) CollageTemplates.zip
              7.) HelpPhotoCollageToolkit.jsx
              8.) LayerToAlphaChan.jsx
              9.) CollageTemplateBuilder.jsx
              10.) TestCollageTemplate.jsx
              11.) InteractivePopulateCollage.jsx
              12.) PopulateCollageTemplate.jsx
              13.) BatchOneImageCollage.jsx
              14.) BatchMultiImageCollage.jsx
              15.) ReplaceCollageImage.jsx
              16.) ChangeTextSize.jsx
              17.) BatchPicturePackage.jsx
              18.) PasteImageRoll.jsx
              19.) PCTpreferences.jsx
              • 4. Re: original file name after making contactsheet.
                Hi JJMack, Thanks for your explanation. I think I did the right actions but the result seems a bit strange.
                But to make a collage is not the hardest thing for me, I can do that with the contactsheets II script in PS. The hardest thing is to save it and rename it automatic with the number of the coin.
                • 5. Re: original file name after making contactsheet.
                  Your results are strange most likely because you did not read the documentation.  I have no idea what you template looked like. The difference between Collage and Contact sheet is collages can have more embellishments, style and image sizing method may be very  different.
                  Here I use  the script and a selected a 16"x16" template file that has 16  (3.5" x 3.5") square images location.
                  I select an Input image folder on my desktop named coin.  In that folder, there are  18 coins Head and Tail. All the same coin.
                  I selected an output folder on my desktop.
                  I checked the option to stamp File name on the image selected the Font and text layer style and also select image layer style 6,  And clicked create collages
                  • 6. Re: original file name after making contactsheet.
                    Thats a good step forward and clear explanation. Thanks a lot!
                    The next thing was to automatic rename the file. so 23423head.tiff and 23423tall.tiff has to combine to the result of a file named 23423.tiff.
                    For that part a ask someone to write a script for me and that works fine. So my problem is solved.
                    Thank you for your help JJMack
                    • 7. Re: original file name after making contactsheet.
                      4000 Coins will take a long time. 8 in a collage like it showed would create 5000 psd file and the batch would take  the better par of a day to run.  I was just learning a bit about script when I create my package and  wanted to see if I could un-populate a collage so that what I did in the script.  I could easily cut the execution time in half and just keep populating the empty template.  I just neve got around to that removing the code and keep to original template open. So  all I need to do is duplicate and populate the dupe..  8000 images are more images then I'll ever process in a batch.
