1 Reply Latest reply on Jan 20, 2016 3:32 PM by George_Johnson
    Need Help: Need number of checkboxes selected to trigger content in text field
    karam40673417
      I am creating a form that has multiple checkboxes the user can select; let's call these checkboxes "cb1", "cb2", "cb3", "cb4", and "cb5". There is a text field (called "cbtotal") that I would like to say different things depending on how many checkboxes are selected. If any 2 checkboxes are selected, I want the text field to say "100". If any 3 checkboxes are selected, I want the text field to say "200". If all 5 checkboxes are selected, I want the text field to say "400". If only 1 checkbox is checked or if 4 checkboxes are checked, the text field can remain blank. How, if at all possible, do I make this all happen?
      Also, can the resulting number (100, 200 or 400) in the "cbtotal" text field be used in a basic sum calculation later on? I want to be able to add that to other text fields in my form for a total at the bottom.
      Thank you all in advance for your help!
        • 1. Re: Need Help: Need number of checkboxes selected to trigger content in text field
          George_Johnson MVP & Adobe Community Professional
          The easiest way is to create a custom calculation script for the cbtotal field. It could look something like:
          // Custom calculation script for text field
          (function () {
              // Initialize variables
              var i, sum = 0;
              // Loop throught the check boxes
              // and count how many are selected
              for (var i = 1; i <= 5; i += 1) {
                  if (getField("cb" + i !== "Off") {
                      sum += 1;
              // Set this field's value based on how many check boxes are selected
              switch (sum) {
              case 2 :
                  event.value = 100;
                  break;
              case 3 :
                  event.value = 200;
                  break;
              case 5 :
                  event.value = 400;
                  break;
              default:
                  event.value = "";  // 0, 1, or 4 check boxes selected
                  break;
          Yes, you can use this calculated field's value in subsequent calculations.
