3 Replies Latest reply on Jan 20, 2016 8:02 PM by robertlue
    Lightroom crashing after each action: import, search, modify or export.
    mjmbkk
      I have reported this problem earlier and it first appeared after deleting the preview folder as suggested solved the problem. After a couple of days  the same problem reoccurred, only now with every action, not just exporting. My setup is the files and catalog are all kept on a 5 TB external drive. The LR catalog properties are: Files-230,000, Folders-5,500 and Size-3.15TB.
      Does this exceed Lightroom's parameters/limitations? I'm guessing there is a delay when the program accesses the data that appears as a fault or problem with the disk. The external disk has been checked and is fine with no faulty sectors.
      Could the problem be solved by transferring  the catalog from the external drive to the computers SSD built in drive?
      and/or
      Should I split the catalog into two separate catalogs? I have kept a single catalog as I often search the entire library for photos.
        • 1. Re: Lightroom crashing after each action: import, search, modify or export.
          Chetna Srivastava Adobe Employee
          Hi mjmbkk,
          Would suggest you to make a copy of the catalog on the local SSD drive and check if it works well there.
          Could you please confirm which version of Lightroom are you using?
          Which operating system and the configuration including memory and RAM?
          Regards,
          Chetna
          • 2. Re: Lightroom crashing after each action: import, search, modify or export.
            mjmbkk Level 1
            Ok, I'll try that.
            Lightroom version: CC 2015.3 [ 1052427 ]
            License: Creative Cloud
            Operating system: Windows 10
            Version: 10.0
            Application architecture: x64
            System architecture: x64
            Logical processor count: 12
            Processor speed: 3.4 GHz
            Built-in memory: 32675.5 MB
            Real memory available to Lightroom: 32675.5 MB
            Real memory used by Lightroom: 1126.4 MB (3.4%)
            Virtual memory used by Lightroom: 1075.5 MB
            Memory cache size: 1239.8 MB
            Maximum thread count used by Camera Raw: 12
            Camera Raw SIMD optimization: SSE2,AVX,AVX2
            System DPI setting: 144 DPI (high DPI mode)
            Desktop composition enabled: Yes
            Displays: 1) 3840x2160, 2) 3840x2160
            Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
            Graphics Processor Info:
            Quadro K4200/PCIe/SSE2
            Check OpenGL support: Passed
            Vendor: NVIDIA Corporation
            Version: 3.3.0 NVIDIA 354.35
            Renderer: Quadro K4200/PCIe/SSE2
            LanguageVersion: 3.30 NVIDIA via Cg compiler
            Application folder: C:\Program Files\Adobe\Adobe Lightroom
            Library Path: J:\LR 5 data-4.lrcat
            Settings Folder: C:\Users\Studio One\AppData\Roaming\Adobe\Lightroom
            • 3. Re: Lightroom crashing after each action: import, search, modify or export.
              robertlue
              Interesting problem...
              I Have a QUADRO K4000 card ...is your GPU being used by Lightroom ...You can get a report under the Performance menu.?
              Lightroom does not pop a screen in my case to say my GPU has been disabled....
              Is your GPU an officially adobe supported GPU?
