1 Reply Latest reply on Jan 21, 2016 10:28 AM by JLGJeanLouis
    RealBezier-> Divide works incorrectly
    tomr11694738 Level 1
      What I'm tryin to do is to divide  a path into 2 equal parts using RealBezier methods.
      That's a sample code:
      AIRealBezier b0, b1, b2;
      error = sAIPath-> GetPathBezier (path, 0, &b0);
      sAIRealBezierSuite-> Divide (&b0, 0.5, &b1,&b2); // t=0.5, gonna divide in half
      Then I assign bezier control points to segments like this:
      segment.p.h = b1.p0.h;
      segment.p.v = b1.p0.v;
      //and so on
      OK, looks good. Works fine with straight lines and symmetrical segments.
      BUT! If there's difference in length of handles (I mean 1st handle is huge, 2nd - tiny), result turns out to be incorrrect (parts are obviously not equal).
      Though it produces smooth result which means that "assigning bezier control points to segments" is done  in a right way.
      Is it normal behaviour of RealBezier Divide?
        • 1. Re: RealBezier-> Divide works incorrectly
          JLGJeanLouis Level 1
          I think that the divide function works correctly.
          //To divide the curve in two equal parts, I first find the length of the bezier segment.
          AIRealBezier b0, b1;
          error=sAIPath->GetPahtBezier(path, 0, &b0);
          LengthOfTheBezierSegment=sAIBezier->Length(&b0, 1.0);
          //I use this length to find the good value of t.
          //LengthOfTheBezierSegment*0.5 is to have the middle of the bezier segment.
          error=sAIBezier->TAtLength(&b0, LengthOfTheBezierSegment, LengthOfTheBezierSegment*0.5, 1.0, &t);
          JLG.
