2 Replies Latest reply on Jan 21, 2016 5:37 PM by A.T. Romano
    How do you change Frame time to Timecode?
    vinz1004
      Im using a PC, and Premier Element 7.
      When I was making a video for class, i dont know what happened and the time code changes into numbers, and not the formatting of 00;00;00.
      How do i converted it back to 00;00;00?
        • 1. Re: How do you change Frame time to Timecode?
          What time code?
          Are you looking a timecode on your video -- or on the program's interface?
          • 2. Re: How do you change Frame time to Timecode?
            A.T. Romano Level 7
            vinz1004
            Premiere Elements 7
            From your description I can interpret it only one way....let us see NTSC Setup
            1. In Premiere Elements 7 here, the time under the monitor is displaying in Timecode 00;00;00;00. If you want that to display in frames, then hold down the Ctrl key of the computer main keyboard and click on the Timecode numbers 00;00;00;00 to switch from Timecode to Frames.
            The other way to do this...Go to Edit Menu/Project Settings/General and Display Format and switch from 30 fps Drop Frame Timecode to Frames.
            If this would be PAL setup....switch from 25 fps Timecode to Frames there.
            Note: the Timecode is represented 00;00;00;00 for NTSC and 00:00:00:00 for PAL.
            Please let us know if that worked for you.
            Thank you.
            ATR
