2 Replies Latest reply on Jan 22, 2016 5:57 AM by joel arvidsson
    Expiration of membership
    annicar36247166
      We have paid for and installed one year licences for Adobe InDesign CC and Adobe Photoshop CC (renewal date December 18, 2016). Everything has worked perfectly fine, but now we get the message "The membership will expire in xx days" when opening the programs. Do we need to act on this?
        • 1. Re: Expiration of membership
          puneeta23771395 Adobe Employee
          It can be a technical issue at your end. Please try following steps
          Mac t/s
          1) Close all adobe related processes in activity monitor (Creative cloud, Core sync, CC library, ccx, services for adobe desktop app, adobe desktop service, Adobe IPC broker, AAM updater)
          2) Navigate to following locations and assign the current user full permissions to adobe folders. To navigate click go from menu bar at then click goto.. type /Library/application support/   and click go.
          3) To assign the permission right click on adobe folder and click Get info.. A property window will open. Then click on lock symbol to enable editing. Then click + sign to add your username. Then change read only to read and write. Then click gear symbol at the bottom and click apply to enclosed items and click ok.. Proceed to next step then.
          3) Navigate to following location /Library/application support/adobe and Delete Slstore and slcache .
          4) Navigate to ~/Library/application support /adobe/oobe and delete opm.db
          5)Navigate to /etc and open hosts file. Check if it has adobe entries . If no its fine, if yes replace the hosts file with a new hosts file with no adobe entries
          6) Launch cc app and it should work fine
          For windows
          1) Close all adobe related processes in task manager (Core sync, services for adobe desktop app, adobe desktop service, Adobe IPC broker, AAM updater)
          2) Navigate to following locations and assign the current user full permissions to adobe folders.  (Right click on adobe folder select properties then click security tab , click edit and select current user you are signed in with , select full control , click apply and then ok)
              C://program data (enable view hidden files to see this folder)
              C://program files 86x/common files
              C://program files/common files
               C: //program files/
          3) rename SLstore to Slstore.old at following location c://program data/Adobe/
          4) Rename SLcache to Slcache.old at following location C:\Program Files (x86)\Common Files\Adobe
          4) Navigate to c://users/username/appdata/local/adobe/oobe and rename Opm.db to opm.old
          5) Navigate to c://windows/system32/drivers/etc/   and open hosts file using notepad. IF you see any Adobe entry there please replace that hosts file with a new hosts file which does not have any adobe entry. If there is no Adobe entry leave the hosts file as it is.
          6) Launch cc app and sign in .
          • 2. Re: Expiration of membership
            joel arvidsson
            I just got something similar.
            I have been a cc member since start and Adobe sent me a mail where the say that I will automaticly continue to be a cc membar 2016. Then Adobe took there usal money a couple of days ago. So whats up Adobe?? Why doesnt the program start?
