1. Re: Keeping form data for later use
WolfShade Jan 22, 2016 7:23 AM (in response to WolfShade)Okay.. here is the test form that I'm working with:
<form name="formthis" id="formthis"> Input a: <input type="text" name="inputa" id="inputa" /> <br />Input b: <input type="password" name="inputb" id="inputb" /> <br />Input c: <select name="inputc" id="inputc"> <option value="">Select</option> <option value="this">THIS</option> <option value="that">THAT</option> </select> <br />Input d: <input type="checkbox" name="inputd" id="inputd_1" value="inputd_1" />1 <input type="checkbox" name="inputd" id="inputd_2" value="inputd_2" />2 <input type="checkbox" name="inputd" id="inputd_3" value="inputd_3" />3 <br />Input e: <select name="inpute" size="3" multiple="multiple" id="inpute"> <option value="Option A">Option A</option> <option value="Option B">Option B</option> <option value="Option C">Option C</option> <option value="Option D">Option D</option> <option value="Option E">Option E</option> </select> <br />Input f: <input type="radio" name="inputf" id="inputf_a" value="Alpha" />Alpha <input type="radio" name="inputf" id="inputf_b" value="Bravo" />Bravo <input type="radio" name="inputf" id="inputf_c" value="Charlie" />Charlie <br /><input type="button" name="submitBtn" id="submitBtn" value="DO IT" onclick="return saForm();" /> <br /><textarea name="txtarea" id="txtarea" width="100%" height="200"></textarea> </form>
The saForm() function is currently set to just iterate through the form elements by name retrieved from the server.
function saForm(){ var thisForm = $('#formthis').serializeArray(), thatForm = JSON.stringify(thisForm), frm = document.getElementById('formthis'), elems = frm.elements; frm.reset(); // Clear form data after submitting, for testing purposes. $.ajax({ type: "POST", url: "doit.cfc?method=myFunction", data: {theData: thatForm} }).done(function(data){ var datab = JSON.parse(data), j;// Turns JSON string into JS array-like object with keys (associative). for(var j in datab){ var frminpt = datab[j], $el = $("[name=" + frminpt.name + "]"), type = $el.attr('type'); alert(frminpt.name + " is a " + type); } }); }
This is working fine, except for single and multiple SELECTs. They alert as undefined. Why? I can't set the selected options if I can't identify the element as a SELECT.
V/r,
^_^
2. Re: Keeping form data for later use
haxtbh Jan 22, 2016 7:29 AM (in response to WolfShade)I would ask this at http://stackoverflow.com/, you will get a response a lot quicker by loads more people.
3. Re: Keeping form data for later use
WolfShade Jan 22, 2016 8:21 AM (in response to haxtbh)I once had an SO account for all of about four days. I requested to have it deleted because SO (and all the associated sites/forums) is more of a popularity contest than an actual help/support forum. There are more trolls and jerks who downvote just for the sake of downvoting than there are people who are serious about helping others. Granted, there are some super-smart people who peruse SO; but they can often be overshadowed by class-a jerks.
V/r,
^_^
4. Re: Keeping form data for later use
WolfShade Jan 25, 2016 6:28 AM (in response to WolfShade)I appreciate haxtbh's suggestion, but it really isn't an option. Is anyone, here, familiar enough with JavaScript and jQuery?
V/r,
^_^
5. Re: Keeping form data for later use
Dave Ferguson Jan 25, 2016 7:04 AM (in response to WolfShade)The select form elements don't have an attribute of type. So, trying to get that attribute would fail. What I would do is add a data attribute to all the fields to store the type.
<select name="inputc" id="inputc" data-type="select">
then update your code to get the field...
var frminpt = datab[j], $el = $("[name=" + frminpt.name + "]"), type = $el.data('type'); alert(frminpt.name + " is a " + type)
hth,
--Dave
6. Re: Keeping form data for later use
WolfShade Jan 25, 2016 7:27 AM (in response to Dave Ferguson)!
I'll give that a shot, Dave Ferguson. Thank you. I'll report back and let you know how it went.
V/r,
^_^
7. Re: Keeping form data for later use
WolfShade Jan 25, 2016 11:57 AM (in response to Dave Ferguson)BRILLIANT!!!
Thanks, Dave Ferguson. I had to make a minor adjustment ($el.attr('data-type') instead of $el.attr('type')) and it works excellent (except it doesn't see a file input, but that's cool.)
Much appreciated.
V/r,
^_^
8. Re: Keeping form data for later use
Dave Ferguson Jan 25, 2016 12:11 PM (in response to WolfShade)Glad it worked for you. Also, you should use $el.data('type'); to get to data attributes not $el.attr('data-type') . This was in my original example but you may have missed it.
--Dave
9. Re: Keeping form data for later use
WolfShade Jan 25, 2016 2:21 PM (in response to Dave Ferguson)I'll give that another shot.. it didn't work until I changed it to 'data-type'.
And, I may have spoke too soon. Your suggestion works for everything except _multiple_ selects (but only because the JSON format doesn't do "fieldName":"Val1,Val3" - it's "fieldName":"Val1","fieldName":"Val3")
Still.. I'm way ahead of where I was before your response. Thank you!
V/r,
^_^
10. Re: Keeping form data for later use
WolfShade Jan 26, 2016 7:25 AM (in response to Dave Ferguson)I'm using $el.data('type'), but when using alert(), it is undefined.
Nevermind.. I was tired, yesterday, and made a mistake that removed the name of the elements, so NOTHING was defined. (sheepish grin)
V/r,
^_^
11. Re: Keeping form data for later use
WolfShade Jan 26, 2016 8:15 AM (in response to Dave Ferguson)Sigh. Now I'm experiencing another issue.
Apparently, when a page with a select-multiple is loaded (ergo, no options are selected), the select-multiple does not exist.
I'm trying to set options selected based upon what is being returned, but I keep getting "$(...).val() is null" and the pointer is pointing to the code that references the select-multiple.
I've tried if(!$('#selectName')){ $('#selectName').val([]);}, but this isn't doing anything, apparently.
How can I initialize a select-multiple upon page load?
V/r,
^_^
12. Re: Keeping form data for later use
WolfShade Jan 26, 2016 12:46 PM (in response to Dave Ferguson)Finally. SMH.
I create a blank array at the start of the function.
Using a for() loop, when it comes to the "select-multiple" type, I .concat() the array.
After the loop, I set the value of the multi-select to that array.
Head-desk! Head-desk! Head-desk!
V/r,
^_^
UPDATE: THERE ARE NO LINKS IN THIS POST. WHY IS IT BEING "MODERATED"?
