2 Replies Latest reply on Jan 23, 2016 8:28 AM by winterm
    Dialog with radiobuttons
    winterm Level 5
      Honorable experts,
      I'm on Win7 64-bit, CS6 (ID 8.1.0.420).
      Scripting skills - somewhere under the "Very Basic" level
      Now trying to adopt to my needs a dialog with radiobuttons, as in Peter Kahrel's Script UI v2-2, pdf page 17:
      var w = new Window ("dialog");
      var radio_group = w.add ("panel");
      radio_group.alignChildren = "left";
      radio_group.add ("radiobutton", undefined, "InDesign");
      radio_group.add ("radiobutton", undefined, "PDF");
      radio_group.add ("radiobutton", undefined, "IDML");
      radio_group.add ("radiobutton", undefined, "Text");
      w.add ("button", undefined, "OK");
      // set dialog defaults
      radio_group.children[0].value = true;
      function selected_rbutton (rbuttons)
      for (var i = 0; i < rbuttons.children.length; i++)
      if (rbuttons.children[i].value == true)
      return rbuttons.children[i].text;
      if (w.show () == 1)
      alert ("You picked " + selected_rbutton (radio_group))
      My version is intended to work on selected text (with Text tool). And here comes the problem.
      After selecting text with Ctrl+A, or Shift+End, or Ctrl+Shift+End -and then- hitting KB shortcut assigned to the script I usually "loose" mouse pointer. It's still here, but turns to be invisible over the whole InDesign window. "Usually" means approx. 5-6 of 10 times... Escaping script window and hitting script shortcut again always works - in next try mouse pointer stays visible. Until you select another portion of text...
      If text was selected with the mouse -or- script is invoked by double-clicking it's name in Scripts palette, everything's fine, always. Also works fine with any other kind of selection.
      Changing KB shortcut has no effect.
      Replacing a mouse has no effect. Microsoft (wired) and Logitech (wireless) optical mice tested.
      However:
      on a fully up-to-date system (Windows 10 Pro N, version 1511, build 10586.63 x64 / InDesign CC 2015.2, build 11.2.0.100 x64) it works - there's no mouse pointer disappearing.
      Have no possibility to test on any other configuration right now.
      Could someone confirm this mouse related volatility on Win7/CS6, or is it somewhat unique to my system?
      And another question:
      Is it possible to enable here cycling through radiobuttons with an arrow keys, like it works in this Marc Autret's script?
      http://www.indiscripts.com/post/2009/09/clean-up-your-pasteboard
      It would let me to live with the 1st problem unsolved... Keyboard-based workflow is preferable anyway.
      Here's is my modified version so far. However, it acts the same way as described above.
      w=new Window("dialog", "Code");
      radio=w.add("panel", undefined, "Choose Action");
      w.alignChildren="fill";
      radio.optionbtns=radio.add("group");
      radio.optionbtns.orientation="column";
      option1=w.add("radiobutton", undefined, "Action One");
      option2=w.add("radiobutton", undefined, "Action Two");
      option3=w.add("radiobutton", undefined, "Action Three");
      option4=w.add("radiobutton", undefined, "Action Four");
      option1.value = true;
                  if (w.show() == 1){
           if (option1.value == true)
           {alert("Action One!"); exit();};
           if (option2.value == true)
           {alert("Action Two!"); exit();};
           if (option3.value == true)
           {alert("Action Three!"); exit();};
            if (option4.value == true)
           {alert("Action Four!"); exit();};
          exit();
      Your comments are greatly appreciated.
      Except upgrading - that's not an option so far, sorry, Adobe...
        • 1. Re: Dialog with radiobuttons
          Jump_Over Level 5
          small modifications, try this:
          var
            w=new Window("dialog", "Code"),
            radio=w.add("panel", undefined, "Choose Action"),
            option1=radio.add("radiobutton", undefined, "Action One"),
            option2=radio.add("radiobutton", undefined, "Action Two"),
            option3=radio.add("radiobutton", undefined, "Action Three"),
            option4=radio.add("radiobutton", undefined, "Action Four");
          radio.alignChildren="left";
          radio.margins = [10,20,10,10];
          function handle_key (key)
            var
            scope = radio.children.length,
            p, newPos, step;
            switch (key.keyName)
            case "Up": step = -1; break;
            case "Down": step = 1; break;
            default : return;
            for (p = 0; p < scope; p++)
            if (radio.children[p].value) {
            newPos = p + step;
            switch (newPos) {
            case scope: newPos = 0; break; // go to first
            case -1: newPos = scope - 1; // go to last
            radio.children[newPos].value = true;
            break;
            } // handle_key
          w.addEventListener ("keydown", function (k) {handle_key (k)});
          if (w.show() == 1){
               if (option1.value) alert("Action One!");
               if (option2.value) alert("Action Two!");
            if (option3.value) alert("Action Three!");
            if (option4.value) alert("Action Four!");
          else {
              exit();
          Cant help you with strange mouse behavior (no idea )
          Jarek
          • 2. Re: Dialog with radiobuttons
            winterm Level 5
            Yeah, the first part of the question probably hasn't a simple answer. Just curious, is this strange mouse behavior unique to my system, otherwise well-tuned, fast and stable.
            As for the "real world" needs, ability to cycle with KB keys fits well for me.
            Thank You, Jarek.
            Bardzo dziękuję!
