• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
"Error! Check authorization"
Community Beginner ,
Jan 22, 2016 Jan 22, 2016
I'm running ADE 4.5 on Windows 7, which I have authorized using my Adobe ID.  I've successfully downloaded DRM-protected PDFs via .acsm files from openlibrary.org in the past.  However, I'm now getting a message "Error!  Check authorization"  I tried uninstalling ADE 4.5 and installing ADE 3.0 and even ADE 2.0, and still get the same error.  In ADE 4.5, I tried erasing authorization information, and after entering my password, I keep getting a message "Unable to erase authorization.  Please try again after some time."
Views
1.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jan 25, 2016 Jan 25, 2016
  1. Close all applications.
  2. Choose Start > Run.
  3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
  4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
  5. Select the Adept key.
  6. Choose File > Export.
  7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
  8. Right-click the Adept key and choose Delete.
  9. In the Confirm Ke
Votes
Translate
Translate
LEGEND ,
  9. In the Confirm Key Delete dialog, click OK.
  10. Close the Registry Editor.
  11. Open Adobe Digital Editions and reauthorize.
Votes
Translate
Translate
Report
Report
Solved it!  Thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Hi, I'm having the same problem as the OP, but I'm running Windows 10, and the steps you laid out don't work for me. Am I doing something wrong? I'm not sure what "Start>Run" is or where to find it in Windows 10. I've never had trouble with ADE before.
Votes
Translate
Translate
Report
Report
This article might help you access the Registry Editor: 5 Ways to Turn on Registry Editor in Windows 10
You should wait until someone confirms that the registry keys are the same in Windows 10 as in Windows 7.
Votes
Translate
Translate
Report
Report
LEGEND ,
Jan 26, 2016 Jan 26, 2016
Press WINDOWS + R. Its the same how run.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 28, 2016 Jan 28, 2016
Thanks, I managed it. Everything is working smoothly now!
Votes
Translate
Translate
Report
Report
LEGEND ,
Jan 31, 2016 Jan 31, 2016
You are welcome.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 09, 2021 Mar 09, 2021
LATEST
Hello,
I am having this same issue. Kobo put me through these steps in detail, and I've reset my Kobo Glo a couple of times. Date and time are set automatically. I have deleted all information, deauthorized, uninstalled, cleared keys, restarted my computer, downloaded ADE 4.5, re-downloaded .acsm file, etc. I'm getting the authorization error, still. Do you know what this could be?
Thanks in advance!
Best,
Laura
Votes
Translate
Translate
Report
Report
