9 Replies Latest reply on Apr 27, 2006 11:47 AM by Newsgroup_User
    GetSQLValueString DW function
    Level 7
      Hi!
      Where can I find documentation about the GetSQLValueString DW function?
      TIA
      Nanu
        • 1. Re: GetSQLValueString DW function
          Level 7
          There isn't any. It simply prepares values for insertion into MySQL by
          adding quotes where necessary and escaping any quotes in user input.
          David Powers
          Author, "Foundation PHP for Dreamweaver 8" (friends of ED)
          Author, "Foundation PHP 5 for Flash" (friends of ED)
          http://foundationphp.com/
          • 2. Re: GetSQLValueString DW function
            Level 7
            Thanks1
            Please explain what will be the $value after executing the following
            statement:
            $value = GetSQLValueString($_GET['foo'], 'text');
            TIA
            Nanu
            • 3. Re: GetSQLValueString DW function
              Level 7
              > statement:
              What I said before:
              The actual result depends on the contents of $_GET['foo']. If it's
              "hello", the result is 'hello'. If it's "don't ask", the result is
              'don\'t ask'.
              David Powers
              • 4. Re: GetSQLValueString DW function
                Level 7
                I used it this way:
                <?php
                $value = GetSQLValueString($_GET['MyVariable'], 'text');
                the server display the message:
                Fatal error: Call to undefined function: getsqlvaluestring() in
                Applic:/HTDocs/k_comm/hebrew/Israel/Tiulim/test5nanu.php on line 36
                What can be the problem?
                TIA
                Nanu
                >> statement:
                > What I said before:
                >>> It simply prepares values for insertion into MySQL by adding quotes
                > 'don\'t ask'.
                • 5. Re: GetSQLValueString DW function
                  Level 7
                  GetSQLValueString() is a custom-built function. You clearly used it in a
                  page where the function hasn't been defined.
                  David Powers
                  • 6. Re: GetSQLValueString DW function
                    Level 7
                    Nanu
                    • 7. Re: GetSQLValueString DW function
                      Level 7
                      .oO(David Powers)
                      It came from a script that I suggested as an example ... but if
                      necessary it should be easy enough to find the source code for that
                      function at Google Groups, it has been posted here multiple times.
                      Micha
                      • 8. Re: GetSQLValueString DW function
                        Level 7
                        You can find the source code very easily by using an insert record or
                        update record server behavior. It's automatically created by
                        Dreamweaver, but it must be in a page (or an include) for you to be able
                        to use it.
                        David Powers
                        • 9. Re: GetSQLValueString DW function
                          Level 7
                          Thanks!
                          Nanu
                          >>> in a page where the function hasn't been defined.
                          > to use it.
