2 Replies Latest reply on Jan 23, 2016 8:48 PM by ojodegato
    Toggle mask single click
    ojodegato Level 1
      I am familiar with the OSX keyboard shortcut click + option to show/hide a layer mask.
      Trying to script this mask toggle behavior. I found a forum script which toggles a layer mask in three clicks.
      1-Click-1 (Selects layer mask)
      2-Click 2 (Shows mask)
      3-Click 3 (Hides  mask and makes layer icon active)
      Now for the tricky part. Can a script toggle a layer mask without making the layer icon active after the toggle effect?
      In other words the script selects the layer mask toggles the mask and keeps the mask icon selected.
      Link to forum script: Re: Selection toggle
        • 1. Re: Toggle mask single click
          cbuliarca Level 3
          You want something like this?
          function isChannelMaskSelected(){
              var ret = false;
              if(hasMask() == true){
                  if(getChannelMaskSel() == true)
                      ret = true;
              else{ret = false}
              return ret;
          function hasMask(){
                  var hasMask = false;
                  var ref = new ActionReference();
                  // var keyHasMask = app.stringIDToTypeID( 'hasUserMask' );
                  var keyHasMask = app.charIDToTypeID( 'UsrM' );
                  ref.putEnumerated( app.charIDToTypeID( 'Lyr ' ), app.charIDToTypeID( 'Ordn' ), app.charIDToTypeID( 'Trgt' ) );
                  var desc = executeActionGet( ref );
                  if ( desc.hasKey( keyHasMask ) ) {
                      hasMask = true;
              return hasMask;
          function selectComponentChannel() {
              try{
                  var map = {}
                  map[DocumentMode.GRAYSCALE] = charIDToTypeID('Blck');
                  map[DocumentMode.RGB] = charIDToTypeID('RGB ');
                  map[DocumentMode.CMYK] = charIDToTypeID('CMYK');
                  map[DocumentMode.LAB] = charIDToTypeID('Lab ');
                  var desc = new ActionDescriptor();
                      ref.putEnumerated( charIDToTypeID('Chnl'), charIDToTypeID('Chnl'), map[app.activeDocument.mode] );
                  desc.putReference( charIDToTypeID('null'), ref );
                  executeAction( charIDToTypeID('slct'), desc, DialogModes.NO );
              }catch(e){}
          function selectChannelMask(visible){
            try {
              ref.putEnumerated( charIDToTypeID( "Chnl" ), charIDToTypeID( "Chnl" ), charIDToTypeID( "Msk " ) );
              desc.putReference( charIDToTypeID( "null" ), ref );
              desc.putBoolean( charIDToTypeID( "MkVs" ), visible );
              executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
              return true;
            } catch (e) { return false;}
          function getChannelMaskVis(){
              var isVisible = false;
                  var keyVisChannels = app.stringIDToTypeID( 'visibleChannels' );
                  if ( desc.hasKey( keyVisChannels ) ) {
                      list = desc.getList(keyVisChannels);
                      // alert("kas key");
                      // alert(desc.getType(keyVisChannels));
                      // alert(list.count);
                      if(list.count > 1)
                          isVisible = false;
                      else{isVisible = true}
              return isVisible;
          function getChannelMaskSel(){
              ref.putProperty( charIDToTypeID( 'Prpr' ), stringIDToTypeID('numberOfChannels') );
              ref.putEnumerated( charIDToTypeID( "Dcmn" ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
              var desc = executeActionGet(ref);
              var numberOfChannels = desc.getInteger(stringIDToTypeID('numberOfChannels'));
              ref.putProperty( charIDToTypeID( 'Prpr' ), stringIDToTypeID( 'targetChannels' ) );
              var list = desc.getList( stringIDToTypeID( 'targetChannels' ) );
              var firstIndex = list.getReference(0).getIndex();
              return list.count == 1 && firstIndex == numberOfChannels+1;
          function toggleChannelMask0(){
              var maskSelected = isChannelMaskSelected();
              if(maskSelected == true){
                  if(getChannelMaskVis() == true)
                      selectComponentChannel();
                  }else{selectChannelMask(true)};
              }else{
                    selectChannelMask(false);
          function toggleChannelMask(){
              }else{
          toggleChannelMask();
          • 2. Re: Toggle mask single click
            ojodegato Level 1
            Right on! Many thanks!
