0 Replies Latest reply on Jan 23, 2016 4:18 PM by Aalokitoaami
    Multiple schemas for different type of Recipients
    Aalokitoaami Level 1
      I have a situation where we need to use 2 different type of Targeting dimensions. One of them is Doctor and other is some general caregiver (who assists aged persons). So do you suggest to create 2 different schemas for these? Here are the different options I thought and pros and cons. So need some expert advice on choosing the best one.
      Option 1:
      - Create new schema for Doctor and use the Recipient Schema (extend as needed) for Caregiver as Caregivers fields are more similar to existing Recipient Schema
      Pros: No need to create 2 schemas
      Cons: You have to consider the heavy lifting of creating a new Delivery Mapping for the Doctor to be available in email personalization
      Options 2:
      - Create 2 new schemas for Doctor and Caregiver
      Pros: No unnecessary fields as many of the default Recipient fields are not needed for either of Doc/Caregiver. So limited null values
      Cons: Same as option 1 but for both the schemas
      Option 3:
      - Use the recipient schema to store both Doctor and Caregiver. Use a field to distinguish the type of records
      Pros: No need to create a new Delivery Mapping and associated complexity
      Cons: There are many distinct fields for Doctor and Caregiver which are not applicable for the other type of record. Thus it will end up having too many null fields for each record. Also for any segmentation you have to run the filtration with the type and then the remaining filtration.
      So please share the most optimum option to be used.
      Also i will appreciate if someone can share some detail documentation for the Delivery Mapping.
