9 Replies Latest reply on Feb 1, 2016 12:41 AM by razvanm77048999
    Lightroom hangs on launch
    _MikeyB Level 1
      Morning, please can somebody help me.
      I'm running Windows 10, 64-bit Pro and Lightroom CC 2015.3.
      After a reboot I can only open Lightroom once, if I close it down and relaunch, it hangs (without an application error and I can not kill the process either and when I try to reboot Windows after the hang I have to physically power the box off as it won't shut down) and the event viewer is kicking up this error:
      Faulting application name: Adobe CEF Helper.exe, version: 3.4.2.183, time stamp: 0x56659f58
      Faulting module name: libcef.dll, version: 3.2171.2069.0, time stamp: 0x551bdc44
      Exception code: 0xc0000005
      Fault offset: 0x00444106
      Faulting process ID: 0x1948
      Faulting application start time: 0x01d15681ba75175e
      Faulting application path: C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\HEX\Adobe CEF Helper.exe
      Faulting module path: C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\CEF\libcef.dll
      Report ID: d47c6614-a61d-446f-83cc-beb86fdc6933
      Faulting package full name:
      Faulting package-relative application ID:
      I thought it might be to do with the Sign out - Sign in issue which I shouldn't have to do every single time I run the app, and I've also tried disabling using the GPU thinking it might be that but with no success.
      Can anyone point me in the right direction please?
        • 2. Re: Lightroom hangs on launch
          _MikeyB Level 1
          Here's my system spec if needed.
          Lightroom version: CC 2015.3 [ 1052427 ]
          License: Creative Cloud
          Operating system: Windows 10
          Version: 10.0
          Application architecture: x64
          System architecture: x64
          Logical processor count: 16
          Processor speed: 3.0 GHz
          Built-in memory: 32669.6 MB
          Real memory available to Lightroom: 32669.6 MB
          Real memory used by Lightroom: 3812.5 MB (11.6%)
          Virtual memory used by Lightroom: 4231.4 MB
          Memory cache size: 5572.3 MB
          Maximum thread count used by Camera Raw: 16
          Camera Raw SIMD optimization: SSE2,AVX,AVX2
          System DPI setting: 144 DPI (high DPI mode)
          Desktop composition enabled: Yes
          Displays: 1) 3840x2160
          Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
          Graphics Processor Info:
          GeForce GTX 980 Ti/PCIe/SSE2
          Check OpenGL support: Passed
          Vendor: NVIDIA Corporation
          Version: 3.3.0 NVIDIA 358.91
          Renderer: GeForce GTX 980 Ti/PCIe/SSE2
          LanguageVersion: 3.30 NVIDIA via Cg compiler
          Application folder: C:\Program Files\Adobe\Adobe Lightroom
          Library Path: S:\Lightroom\Lightroom Catalog.lrcat
          Settings Folder: C:\Users\MikeyB\AppData\Roaming\Adobe\Lightroom
          Installed Plugins:
          1) Canon Tether Plugin
          2) Facebook
          3) Flickr
          4) Leica Tether Plugin
          5) Nikon Tether Plugin
          Config.lua flags: None
          Adapter #1: Vendor : 10de
            Device : 17c8
            Subsystem : 854f1043
            Revision : a1
            Video Memory : 6048
          Adapter #2: Vendor : 1414
            Device : 8c
            Subsystem : 0
            Revision : 0
            Video Memory : 0
          AudioDeviceIOBlockSize: 1024
          AudioDeviceName: Line Out (3- Scarlett 2i2 USB)
          AudioDeviceNumberOfChannels: 2
          AudioDeviceSampleRate: 44100
          Build: Uninitialized
          Direct2DEnabled: false
          GPUDevice: not available
          OGLEnabled: true
          • 3. Re: Lightroom hangs on launch
            DdeGannes Adobe Community Professional
            Have a look at this thread and see if it helps.
            lightroom CC not loading
            With respect to the Sign Out / Sign In issue try using the Quit Lightroom option from the Lightroom menu bar.
            Sign Out = Deactivate
            Sign In = Activate
            • 4. Re: Lightroom hangs on launch
              _MikeyB Level 1
              Thanks Per, I'll give that a try and see how I get on.
              • 5. Re: Lightroom hangs on launch
                _MikeyB Level 1
                Thanks - I've tried the sign out and sign in options but don't want to do that everytime I open Lightroom.
                • 6. Re: Lightroom hangs on launch
                  If you use the quit option you should not have to Sign In the next time you start Lightroom.
                  • 7. Re: Lightroom hangs on launch
                    Per Berntsen Adobe Community Professional
                    I have posted some more suggestions in the other thread that DdeGannes linked to in post 3.
                    • 8. Re: Lightroom hangs on launch
                      _MikeyB Level 1
                      Thanks for everyone who's taken their time to reply, much appreciated as this has been doing my head in for a few weeks.
                      What I have done - and everything is running smoothly again is, delete all the preferences, delete all the cache including any smart or 1:1 previews and it's now working as expected.
                      I'll keep this thread up to date if I get the problem again and I'll try narrow down the actual problem and solution but hopefully this may help somebody.
                      • 9. Re: Lightroom hangs on launch
                        razvanm77048999
                        What do you mean all preferences?
