4 Replies Latest reply on Jan 25, 2016 2:33 AM by joel_pau
    Text field count from 20:00 to 00:00
    Thomas83
      Hi
      I want to make a text field that count down from 20:00 (mins) to 00:00. Can someone help me?
      I have succeded to count up with the code below.
      secs = 00;
      mins = 00;
      hours = 00;
      sym.$('secs').html(secs);
      sym.$('mins').html(mins);
      sym.$('hours').html(hours);
      var t = setInterval(function(){myCounter()}, 1000);
      function myCounter() {
        secs++;
        if(secs==59){
        secs = -01;
        mins++;
        if(mins==9){
        //secs = 59;
        mins = 0;
        hours++;
        if ( hours == 3){
        clearInterval(t);
        secs = 0;
        mins = 0;
        hours =3;
        • 1. Re: Text field count from 20:00 to 00:00
          joel_pau Level 5
          Here is an attempt ==> countDown.zip - Box
          var duration = 60*20, minutes, seconds;
          var startTimer = function () {
          minutes = parseInt(duration / 60, 10);
          seconds = parseInt(duration % 60, 10);
          minutes = minutes < 10 ? "0" + minutes : minutes;
          seconds = seconds < 10 ? "0" + seconds : seconds;
          sym.$("min").html(minutes);
          sym.$("sec").html(seconds);
          var countdown = setTimeout(startTimer, 1000);
          if (--duration < 0) { clearInterval(countdown); };
          startTimer();
          • 2. Re: Text field count from 20:00 to 00:00
            Thomas83 Level 1
            Thank you soo much Joel. You made my day!
            One question, if i put mins and secs in a symbol, what do I need to change in the code?
            Best regards
            Thomas
            • 3. Re: Text field count from 20:00 to 00:00
              joel_pau Level 5
              Well, 2 ideas:
              1) With your symbol, you create a creationComplete panel using the user interface (the button "+"). Then, you copy and paste the countdown code.
              2) You don't move the code and you just change these lines:
              sym.getSymbol("symbolName").$("min").html(minutes);
              sym.getSymbol("symbolName").$("sec").html(seconds);
              • 4. Re: Text field count from 20:00 to 00:00
                joel_pau Level 5
                A better code and a new demo.
                • Code:
                var countdown, duration = 60*20, minutes, seconds,
                  sym.$("min").text(minutes);
                  sym.$("sec").text(seconds);
                  if (--duration < 0) { clearTimeout(countdown); };
                startTimer();
                Note:
                Here duration is twenty minutes because: duration = 60*20.
                So, if you want 5 minutes: duration = 60*5
