2 Replies Latest reply on Sep 28, 2016 7:41 AM by alexonNook
    I'm getting the following error message on my Nook. Error dialog, user not activated.  This has just started happening.
    cherielavanture
      I'm getting the following error message on my Nook. Error dialog, user not activated.  This has just started happening.I checked and my PC is authorized.
        • 1. Re: I'm getting the following error message on my Nook. Error dialog, user not activated.  This has just started happening.
          Nanaky Level 5
          1. Close all applications.
          2. Choose Start > Run.
          3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
          4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
          5. Select the Adept key.
          6. Choose File > Export.
          7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
          8. Right-click the Adept key and choose Delete.
          9. In the Confirm Key Delete dialog, click OK.
          10. Close the Registry Editor.
          11. Open Adobe Digital Editions and reauthorize.
          • 2. Re: I'm getting the following error message on my Nook. Error dialog, user not activated.  This has just started happening.
            alexonNook Level 1
            Sep 2016 - I have only recently bought a Nook (Simple Touch Glowlight 4GB) and have had the error, 'User not activated', with 3 of the eBooks I have bought from online retailers.  (I live in the UK and we are not allowed to buy directly from Barnes and Noble !!)
            I have been receiving an '.acsm' file then downloading the EPUB file using Adobe Digital Editions.  At this point I can read the book on screen on my iMac but when I sideload it on to my Nook, the Nook does not allow me to read it - 'User not activated'.
            I have then used an independent, free, eBook program called, 'Calibre', to load the first, downloaded EPUB file into Calibre's own 'library'.  At this point I go to the Calibre Library folder on the Mac and copy that version directly on to the Nook.
            I don't understand what the difference is or why it works - I did wonder if Calibre stripped out the copyright (DRM) stuff from the eBook but I don't believe it can do that.
            If you have received an EPUB file from your library, try loading that into Calibre and using the fresh Calibre version on the Nook as above.
            I hope this helps.
