6 Replies Latest reply on Jan 26, 2016 1:45 PM by Qwertyfly...
    Undefined is not an object
    CheckPleaseTY
      Hello! I need to export layer information including coordinates, layer names and font information to a json tree to make my life a little bit easier.
      When I run the script, I get the following error:
      Error 21: undefined is not an object.
       fontFamily[i] = child.textRange.characterAttributes.textFont.family;
      If I comment out that line (687 below), it will continue to error out until I have removed all the font properties. I suspect it is a syntax error since this script was originally created for CS4 and I am running CC 2015. I looked at the documentation, but have yet to figure it out from my limited knowledge.
      Here is the complete script and thanks for the help:
      // Export Layout - Adobe Illustrator Script
      // Description: Export x and y coordinates to JSON
      // Requirements: Adobe Illustrator CS4 or greater
      // Version: 1.0-beta8
      // Installation:
      // 1. Place script in
      //        Mac: '~/Applications/Adobe Illustrator CS#/Presets/Scripts/'
      //        Win: 'C:\Program Files\Adobe\Adobe Illustrator CS#\Presets\en_US\Scripts\'
      // 2. Restart Illustrator
      // 3. Choose File > Scripts > Export Layout
          This script will output a JSON tree representing the content.
          Layers , Groups, and PageItems  are arranged in a tree,
          those with #tags in the name are labeled as UI elements
          @tags are used to specifiy alignment to the parent
          All coordinates are absolute
      // Enables double-click launching from the Mac Finder or Windows Explorer
      #target illustrator
      // Set active Document variable and decode name for output
      // Define the rect bounds of the artboard
      var document = app.activeDocument;
      var documentName = decodeURI(activeDocument.name);
      //var colorSpace = document.DocumentColorSpace.RGB;
      var dX = document.artboards[0].artboardRect[0];
      var dY = document.artboards[0].artboardRect[3];
      var dX2 = document.artboards[0].artboardRect[2];
      var dY2 = document.artboards[0].artboardRect[1];
      // Layer variables
      var layerNum = 0;
      // Tag variables
      var nameO = []; // is strings without tags
      var id = []; // $identifier
      var type = []; // #type
      var align = []; /* @align */
      var attach = []; // %attach
      var variable = []; // &variable
      // Define varible for object position
      var output = "";
      // Automatically indent JSON output
      var tabCount = 0;
      // PNG option variables
      var options = new ExportOptionsPNG24();
      options.antiAliasing = true;
      options.transparency = true;
      options.artBoardClipping = true;
      var pngNum = 0;
      // Color variables
      fillColor = [];
      strokeColor = [];
      // Text variables
      var fontFamily = [];
      var fontStyle = [];
      var fontSize = [];
      var fontJustification = [];
      var fontFillColor = [];
      var fontStrokeColor = [];
      var fontStrokeWeight = [];
      //~ var kerning = [];
      //~ var kerningMethod = [];
      var tracking = [];
      var leading = [];
      var textContent = [];
      /*____________________________________
                Tab
      adds to output the given string with current indentation
      ____________________________________*/
      function tab(s) {
          for ( var t = 0; t< tabCount; t++ ) {
            output += "   ";
          if ( s !== 'undefined' ) {
            output += s;
              Process Document
      Prints Names of all the sublayers
      and the items on the layers
      function processDocument(D) {
        tab("{\n");
        tabCount+=1;
        tab("\"Document\":\""+D.name+"\",\n");
        tab("\"Date\":\""+new Date()+"\",\n");
        tab("\"x\":\""+Math.round(dX)+"\",\n");
        tab("\"y\":\""+Math.round(dY)+"\",\n");
        tab("\"w\":\""+(dX2-dX)+"\",\n");
        tab("\"h\":\""+(dY2-dY)+"\",\n");
        //Maybe here we rasterize the index list of pageObject
        //traversePageItems(layer);
        tab("\"children\":\n");
        tab("[\n");
        traverseLayers(D);
        tab("]\n");
        tabCount-=1;
        tab("}\n");
        Translate Tag
      function translateTag(t) {
        if ( t === "#btn" ) {
          return "button";
        if ( t === "btn" ) {
          return "button";
        if ( t === "#btnToggle" ) {
          return "toggle";
        if ( t === "btnToggle" ) {
          return "toggle";
        if ( t === "#icon" ) {
          return "image";
        if ( t === "icon" ) {
          return "image";
        if ( t === "#txt" ) {
          return "text";
        if ( t === "txt" ) {
          return "text";
        if ( t === "#text" ) {
          return "text";
        if ( t === "#valueBar" ) {
          return "valueBar";
        if ( t === "#fillingBar" ) {
          return "fillingBar";
        if ( t === "#rectangle" ) {
          return "rectangle";
        if ( t === "#bg" ) {
          return "rectangle";
        if ( t === "bg" ) {
          return "rectangle";
        return t;
      /*__________________________________________
            Number Of Visible Pages
      __________________________________________*/
      function numberOfVisiblePageItems(layer) {
        num = 0;
        for ( var i =0; i<layer.pageItems.length; i++ ) {
          if ( !layer.pageItems[i].hidden ) {
            num++;
            return num;
            Number of Visible Sublayers
      function numberOfVisibleSubLayers(layer) {
        num = 0;
        for ( var i =0; i<layer.layers.length; i++ ) {
          if ( layer.layers[i].visible ) {
              num++;
              return num;
                Get X
      function getX(layer) {
        X = 0;
        for ( var i = 0; i < layer.pageItems.length; i++ ) {
          item = layer.pageItems[i];
          if ( !item.hidden ) {
            if ( item.position[0] < X ) {
              X = item.position[0];
        for ( var i = 0; i < layer.layers.length; i++ ) {
          L = layer.layers[i];
          if ( L.visible ) {
            newX = getX(L);
            if ( newX < X ) {
              X = newX;
        return Math.round(X);
                  Get Y
      function getY(layer) {
        Y = 0;
            if ( item.position[1] < Y ) {
                Y = item.position[1];
          if ( L.visible ) {
            newY = getY(L);
            if ( newY < Y ) {
              Y = newY;
        return Math.round(Y);
                  Get W
      function getW(layer) {
        W = 0;
        max = 0;
          newMax = item.position[0]-dX+item.width;
            if ( newMax > max ) {
                max = newMax;
        W = max - getX(layer);
          if ( L.visible ) {
            newW = getW(L);
            if ( newW > W ) {
              W = newW;
        return Math.round(W);
              Get H
      function getH(layer) {
        H = 0;
        max = 0;
          newMax = item.position[1]-dY;
              max = newMax;
        H = max - getY(layer);
          if ( L.visible ) {
            newH = getH(L);
            if ( newH > H ) {
              H = newH;
        return Math.round(H);
              Process Layer
      function processLayer(layer) {
        tabCount=tabCount+1;
        layerNum++;
        //Set tag arrays to none so non present tags won't come up undefined
        id[this.layer] = "NONE";
        type[this.layer] = layer.typename;
        align[this.layer] = "NONE";
        attach[this.layer] = "NONE";
        variable[this.layer] = "NONE";
        //Parse Tags from the name, set type
        //This could be in a separate function(s)
        var layerName = layer.name.split (" ");
        check = 0;
        // loop through layer name that was split into an array
        for ( var ii = 0; ii < layerName.length; ii++ ) {
          // Gather Name
          if ( layerName[ii].indexOf("$") == -1 &&
               layerName[ii].indexOf("#") == -1 &&
               layerName[ii].indexOf("@") == -1 &&
               layerName[ii].indexOf("%") == -1 &&
               layerName[ii].indexOf("&") == -1 )
            nameO[this.layer] = layerName[ii];
          else if ( ii === layer.name.length ) {
            nameO[this.layer] = "NONE";
          // Check for ID tag
          if ( layerName[ii].indexOf("$") !== -1 ) {
            id[this.layer] = layerName[ii].toLowerCase().slice(1);
            id[this.layer]=translateTag(id[this.layer]);
            check = 1;
          else if ( ii === layer.name.length && check === 0 ) {
            id[this.layer] = "layer";
            check = 0;
          // Check for type tag
          if ( layerName[ii].indexOf("#") !== -1 ) {
            type[this.layer] = layerName[ii].toLowerCase().slice(1);
            type[this.layer]=translateTag(type[this.layer]);
            check = 1;
          else if ( check === 0 && ii === layerName.length ) {
            type[this.layer] = translateTag(type[this.layer]);
            check = 0;
          // Check for align tag
          if ( layerName[ii].indexOf("@") !== -1 ) {
            align[this.layer] = layerName[ii].toUpperCase().slice(1);
            align[this.layer]=translateTag(align[this.layer]);
          else if ( ii === layerName.length ) {
          // Check for attach tag
          if ( layerName[ii].indexOf("%") !== -1 ) {
            attach[this.layer] = layerName[ii].toLowerCase().slice(1);
            attach[this.layer]=translateTag(attach[this.layer]);
          // Check for variable tag
          if ( layerName[ii].indexOf("&") !== -1 ) {
            variable[this.layer] = layerName[ii].toLowerCase().slice(1);
            variable[this.layer]=translateTag(variable[this.layer]);
        if ( layer.visible ) {
          //Visible Layer
          tab("\"name\":\""+nameO[this.layer]+"\",\n");
          tab("\"id\":\""+id[this.layer]+"\",\n");
          tab("\"type\":\""+type[this.layer]+"\",\n");
          tab("\"align\":\""+align[this.layer]+"\",\n");
          tab("\"attach\":\""+attach[this.layer]+"\",\n");
          tab("\"variable\":\""+variable[this.layer]+"\",\n");
          tab("\"x\":\"" + getX(layer)  +"\",\n");
          tab("\"y\":\"" + getY(layer)  +"\",\n");
          tab("\"w\":\"" + getW(layer) +"\",\n");
          tab("\"h\":\"" + getH(layer)  +"\",\n");
          tab("[\n");
          //Print Page Items out as Children
          if ( numberOfVisiblePageItems(layer) > 0 ) {
            if ( numberOfVisibleSubLayers(layer) > 0 ) {
              tab(",\n");
          //Print Layers out as Children
          traverseLayers(layer);
          tab("]\n");
          tabCount = tabCount -1;
        else {
          //Invisible Layer
          tab("\"name\":\""+"HIDDEN LAYER"+"\",\n");
          tab("\"type\":\""+"HIDDEN LAYER "+ type[this.layer]+"\"\n");
            Traverse Children
        go through layers
      function traverseLayers(parent) {
        if ( parent.layers.length > 0 ) {
          tabCount = tabCount + 1;
          for ( var ii = 0; ii < parent.layers.length; ii++ ) {
            //Open layer '{'
            child = parent.layers[ii];
            tab("{\n");
            processLayer(child);
            //  last child close '}'
            //  not last child comma '},'
            if ( ii === parent.layers.length - 1 ) {
              tab("}\n");
            else {
              tab("},\n");
          tabCount = tabCount - 1;
            Parse Name
      function parseName(child, i) {
        if ( child.name.length <= 0 ) {
          //Reset tag arrays so children won't inherit parent's values
          nameO[i] = "NONE";
          id[i] = "NONE";
          type[i] = child.typename;
          align[i] = "NONE";
          attach[i] = "NONE";
          variable[i] = "NONE";
        else {
          childName = child.name.split(" ");
          var check = 0;
          var nameBox = [];
          for ( var ii = 0; ii < childName.length; ii++ ) {
            // loop through child name that was split into an array to pick out tags
            // Gather name
            if ( childName[ii].indexOf("$") === -1 &&
                 childName[ii].indexOf("#") === -1 &&
                 childName[ii].indexOf("@") === -1 &&
                 childName[ii].indexOf("%") === -1 &&
                 childName[ii].indexOf("&") === -1 ) {
              nameO[i] = childName[ii];
              check = 1;
            else if ( check === 0 ) {
              nameO[i] = "NONE";
            // Check for ID tag
            if ( childName[ii].indexOf("$") !== -1 ) {
              id[i] = childName[ii].toLowerCase().slice(1);
              id[i]=translateTag(id[i]);
            else if ( ii === child.name.length ) {
              id[i] = "NONE";
            if ( childName[ii].indexOf("#") !== -1 ) {
              type[i] = childName[ii].toLowerCase().slice(1);
              type[i] = translateTag(type[i]);
            else if (ii === childName.length) {
            if ( childName[ii].indexOf("@") !== -1 ) {
              align[i] = childName[ii].toUpperCase().slice(1);
              align[i]=translateTag(align[i]);
            else if ( ii === childName.length ) {
              align[i] = "NONE";
            if ( childName[ii].indexOf("%") !== -1 ) {
              attach[i] = childName[ii].toLowerCase().slice(1);
              attach[i]=translateTag(attach[i]);
              attach[i] = "NONE";
            if ( childName[ii].indexOf("&") !== -1 ) {
              variable[i] = childName[ii].toLowerCase().slice(1);
              variable[i]=translateTag(variable[i]);
        // Check if element is Placed Item
        if ( child.typename === "PlacedItem" ) {
          nameO[i] = "No Linked PlacedItem";
        // Check if element is Path Item
        // then add color information
        if ( child.typename === "PathItem" ) {
          fillColor[i] = child.fillColor;
          strokeColor[i] = child.strokeColor;
        // Check if element is TextFrame
        // then add font information
        if ( child.typename === "TextFrame" ) {
          fontStyle[i] = child.textRange.characterAttributes.textFont.style;
          fontSize[i] = child.textRange.characterAttributes.size;
          fontJustification[i] = child.textRange.paragraphAttributes.justification;
          tracking[i] = child.textRange.characterAttributes.tracking;
          fontFillColor[i] = child.textRange.characterAttributes.fillColor;
          fontStrokeColor[i] = child.textRange.characterAttributes.strokeColor;
          fontStrokeWeight[i] = child.textRange.characterAttributes.strokeWeight;
          leading[i] = child.textRange.characterAttributes.leading;
          textContent[i] = child.textRange.contents;
            Process Page Item
      function processPageItem(child, i) {
        var cX = child.position[0];
        var cY = child.position[1];
        var X  = Math.round(cX - dX);
        var Y  = Math.round((cY - dY)- child.height);
        var W = Math.round(child.width);
        var H  = Math.round(child.height);
        parseName(child, i);
        tab("\"name\":\"" + nameO[i] + "\",\n");
        tab("\"id\":\"" + id[i] + "\",\n");
        tab("\"type\":\"" + type[i] + "\",\n");
        tab("\"align\":\"" + align[i] + "\",\n");
        tab("\"attach\":\"" + attach[i] + "\",\n");
        tab("\"variable\":\"" + variable[i] + "\",\n");
        // Output color information for PathItems
          // Fill Colors
          if ( fillColor[i].typename === "RGBColor" ) {
            tab("\"fill color type\":\"" + fillColor[i].typename + "\",\n");
            tab("\"fill r\":\"" + fillColor[i].red + "\",\n");
            tab("\"fill g\":\"" + fillColor[i].green + "\",\n");
            tab("\"fill b\":\"" + fillColor[i].blue + "\",\n");
            tab("\"fill a\":\"" + child.opacity + "\",\n");
          else if ( fillColor[i].typename === "GrayColor" ) {
            tab("\"fill gray\":\"" + fillColor[i].gray + "\",\n");
          else if ( fillColor[i].typename === "GradientColor" ) {
            tab("\"fill color type\":\"" + fillColor[i].typename + "\"" + ",\n");
          else if ( fillColor[i].typename === "NoColor" ) {
            tab("\"fill color type\":\"" + fillColor[i].typename + "\"" + "\",\n");
          // Stroke Colors
          if ( strokeColor[i].typename === "RGBColor" ) {
            tab("\"stroke color type\":\"" + strokeColor[i].typename + "\",\n");
            tab("\"stroke r\":\"" +  strokeColor[i].red + "\",\n");
            tab("\"stroke g\":\"" +  strokeColor[i].green + "\",\n");
            tab("\"stroke b\":\"" + strokeColor[i].blue + "\",\n");
            tab("\"stroke a\":\"" + child.opacity + "\",\n");
          else if ( strokeColor[i].typename === "GrayColor" ) {
            tab("\"stroke gray\":\"" + strokeColor[i].gray + "\",\n");
          else if ( strokeColor[i].typename === "GradientColor" ) {
            tab("\"stroke color type\":\"" + strokeColor[i].typename + "\"" + ",\n");
          else if ( strokeColor[i].typename === "NoColor" ) {
        // Output font information for TextFrames
          tab("\"font family\":\"" + fontFamily[i] + "\"" + ",\n");
          tab("\"font style\":\"" + fontStyle[i] + "\"" + ",\n");
          tab("\"font size\":\"" + fontSize[i] + "\"" + ",\n");
          tab("\"font stroke weight\":\"" + fontStrokeWeight[i] + "\"" + ",\n");
          var justify = String(fontJustification[i]);
          justify = justify.split(".")[1];
          tab("\"paragraph justification\":\"" + justify.toLowerCase() + "\"" + ",\n");
          tab("\"tracking\":\"" + tracking[i] + "\"" + ",\n");
          tab("\"leading\":\"" + leading[i] + "\"" + ",\n");
          // Font Fill Colors
          if ( fontFillColor[i].typename === "RGBColor" ) {
            tab("\"font fill color type\":\"" + fontFillColor[i].typename + "\",\n");
            tab("\"font fill r\":\"" + fontFillColor[i].red + "\",\n");
            tab("\"font fill g\":\"" + fontFillColor[i].green + "\",\n");
            tab("\"font fill b\":\"" + fontFillColor[i].blue + "\",\n");
            tab("\"font fill a\":\"" + child.opacity + "\",\n");
          else if ( fontFillColor[i].typename === "GrayColor" ) {
            tab("\"font fill gray\":\"" + fontFillColor[i].gray + "\",\n");
          else if ( fontFillColor[i].typename === "GradientColor" ) {
            tab("\"font fill color type\":\"" + fontFillColor[i].typename + "\"" + ",\n");
          else if ( fontFillColor[i].typename === "NoColor" ) {
            tab("\"font fill color type\":\"" + fontFillColor[i].typename + "\"" + "\",\n");
          // Font Stroke Colors
          if ( fontStrokeColor[i].typename === "RGBColor" ) {
            tab("\"font stroke color type\":\"" + fontStrokeColor[i].typename + "\",\n");
            tab("\"font stroke r\":\"" + fontStrokeColor[i].red + "\",\n");
            tab("\"font stroke g\":\"" + fontStrokeColor[i].green + "\",\n");
            tab("\"font stroke b\":\"" + fontStrokeColor[i].blue + "\",\n");
            tab("\"font stroke a\":\"" + child.opacity + "\",\n");
          else if ( fontStrokeColor[i].typename === "GrayColor" ) {
            tab("\"font stroke gray\":\"" + fontStrokeColor[i].gray + "\",\n");
          else if ( fontStrokeColor[i].typename === "GradientColor" ) {
            tab("\"font stroke color type\":\"" + fontStrokeColor[i].typename + "\"" + ",\n");
          else if ( fontStrokeColor[i].typename === "NoColor" ) {
            tab("\"font stroke color type\":\"" + fontStrokeColor[i].typename + "\"" + "\",\n");
          tab("\"text content\":\"" + textContent[i] + "\"" + ",\n");
        tab("\"x\":\"" + X + "\",\n");
        tab("\"y\":\"" + Y  + "\",\n");
        tab("\"w\":\"" + W + "\",\n");
        tab("\"h\":\"" + H + "\",\n");
          Export PNGs
        if ( type[i] === "image" || type[i] === "icon" || type[i] === "button" ) {
          var png = new File(FPath.fsName+"/"+childName+".png");
          var scratchDoc = app.documents.add(DocumentColorSpace.RGB, child.width, child.height);
          scratchDoc.pageOrigin = [0,0];
          child.duplicate(scratchDoc, ElementPlacement.PLACEATEND);
          var item = scratchDoc.activeLayer.pageItems[0];
          item.translate(-item.position[0], -item.position[1] + child.height);
          scratchDoc.exportFile(png,ExportType.PNG24,options);
          scratchDoc.close(SaveOptions.DONOTSAVECHANGES);
          pngNum++;
        if ( child.typename === "GroupItem" ) {
          tab("[\n");
          traversePageItems (child);
          tab("]\n");
            traverse Page Items
      function traversePageItems(layer) {
        layerNum++;
        var offset; //switch between names with and without #types, set to 1 or 0
          child = layer.pageItems[i];
          if ( !child.hidden ) {
            tab("{\n");
            tabCount++;
            processPageItem(child), i;
            tabCount-=1;
            if ( i === layer.pageItems.length - 1 ) {
              tab("}\n");
            else {
              tab("},\n");
          Write File
      function writeFile(info) {
        try {
          var f = new File(FPath + "/" + documentName + ".txt");
          f.open('w');
          f.lineFeed = fileLineFeed;
          f.write(info);
          f.close();
        catch(e){}
      // Ask the user for the folder to export to
      var FPath = Folder.selectDialog("Save exported coordinates and PNGs to") ;
      // Detect line feed type
      if ( $.os.search(/windows/i) !== -1 ) {
        fileLineFeed = "Windows";
      else {
        fileLineFeed = "Macintosh";
      // Run the functions
      processDocument(document);
      writeFile(output);
      // Export document PNG
      var docPng = new File(FPath.fsName+"/"+documentName+".png");
      document.exportFile(docPng, ExportType.PNG24);
      pngNum++;
      // Show results
      if ( FPath === null ) {
        alert ("Export aborted", "Canceled");
      else {
        alert( "Exported " +
              layerNum +
              " layer's coordinates and " +
              pngNum +
              " PNGs to " +
              translateTag(FPath),
        "Success!");
        • 1. Re: Undefined is not an object
          Qwertyfly... Level 4
          I'll take a stab in the dark and guess that it may have something to do with an empty text frame in the document.
          • 2. Re: Undefined is not an object
            pixxxel schubser MVP & Adobe Community Professional
            Hmmh. There are a little bit lines of code.
            One shot in the sky:
            Are you sure, that line 875 is correct?
            • 3. Re: Undefined is not an object
              with out testing I would say that is the trouble.
              nice find Pix.
              the function processPageItem askes for child and i.
              the line,
              should look more like
              processPageItem(child,i);
              • 4. Re: Undefined is not an object
                CheckPleaseTY Level 1
                So a few things. You are correct that there was an empty text frame. I figure it would still export since it will export an empty path frame.
                It will run the script with text in the black text frame, however the text file output doesn't actually print any values:
                "name":"TestTextFrame",
                               "id":"NONE",
                               "type":"Layer",
                               "align":"NONE",
                               "attach":"NONE",
                               "variable":"NONE",
                               "font family":"undefined",
                               "font style":"undefined",
                               "font size":"undefined",
                               "font stroke weight":"undefined",
                               "tracking":"undefined",
                               "leading":"undefined",
                               "text content":"undefined",
                               "x":"182",
                               "y":"11",
                               "w":"102",
                               "h":"35",
                Changing that line to processPageItem(child,i); give me an Invalid Argument error when trying to run the script on the same file for line fontFamily[i] = child.textRange.characterAttributes.textFont.family;
                • 5. Re: Undefined is not an object
                  I needed to fix the line as mentioned above.
                  then it wigs out on empty text text frame.
                  the fix depends on what you want reported when an empty text frame is found.
                  the below code adds some temporary text so frame can be logged then removes the text so document is left unchanged
                      if(child.textRange.contents == "") {
                          child.textRange.contents = "temporary test text";
                      if(child.textRange.contents == "temporary test text") {
                          child.textRange.contents = "";
                  • 6. Re: Undefined is not an object
                    I'm glad I could help you out.
                    Sing out if we can help with anything else.
