4 Replies Latest reply on Jan 25, 2016 12:41 PM by A.T. Romano
    FILM  FOND  ROUGE
    michelp63459618
      FILM VIDEO   ECRAN FOND ROUGE
        • 1. Re: FILM  FOND  ROUGE
          michelp63459618 Level 1
          MEDIA OFF-LINE
          • 2. Re: FILM  FOND  ROUGE
            A.T. Romano Level 7
            michelp
            What are you trying to tell us -
            a. you opened a saved closed project and was greeted with "Where is the file ______?" messages? And, if you clicked Skip All to the first message, you went into the project to find colorful Media Offline displays?
            or
            b. your video imported with frames that were colored red frame?
            The first would suggest that you moved, deleted, or renamed files that were connected to the project. Or, if you store your files on an external hard drive, the external hard drive may not be working correctly.
            And, the second would suggest a video codec/format issue.
            Please consider, give more details, and let us know if you have resolved your own issue.
            Thank you.
            ATR
            • 3. Re: FILM  FOND  ROUGE
              media  ofrf-line sur mon fim a visualiser
              Message du 25/01/16 18:32
              De : "A.T. Romano"
              A : "michel petit"
              Copie à :
              Objet :  FILM  FOND  ROUGE
              FILM  FOND  ROUGE
              created by A.T. Romano in Premiere Elements - View the full discussion
              michelpWhat are you trying to tell us -
              • 4. Re: FILM  FOND  ROUGE
                A.T. Romano Level 7
                michelp
                The translation is not good.
                Is your problem solved?
                If "Where is the file ______?" messages, have you used them to reconnect the files that are disconnected from the project file? If you do not know how to do that, I will give details.
                If you take your video to the Timeline track and see all red frames, then please tell us the properties of the video (video compression, file extension, brand/model/settings for the camera that recorded the video).
                We want to make sure if your problem is solved or not.
                Thank you.
                ATR
