3 Replies Latest reply on Jan 27, 2016 9:51 AM by Peter Grainge
    Can I create a Merged Help out of two existing Projects?
    Stellas Level 1
      I have an existing RH11 Project (Project A) that is on RoboHelp Source Control.  It is called up within the software that it is written for .  My company developed an add-on software to the original software.  I have about 30% of Help for the add-on (Project B) completed but it is not in Source Control.  The developer just informed me that the Help file needs to be one Help. ( I did ask this question in the beginning).  Is there a way for me to create a Merged Help project out of the two existing Projects and have it in Source Control?  I have created Merged Help before so I have some familiarity with it. I have Peter Grainge's RoboHelp authoring site bookmarked.
      Thanks in advance for any direction you can provide.
        • 1. Re: Can I create a Merged Help out of two existing Projects?
          We need to know what the developer means by "one help". Merged help is two or more projects, each with their own output that can be called independently but can also be presented to appear as on output.
          If that satisfies the developer's stipulation, then yes you can set up your existing projects to do that. The parent as described on my site would be empty and your two projects would be the child projects. Each would be in source control.
          @petergrainge
          • 2. Re: Can I create a Merged Help out of two existing Projects?
            Stellas Level 1
            Thank you for your quick response:  The developer maps each screen in our software to a page in the Help system.  If we transition Project A ( published and mapped)  into a child in a new Merged Help Project will all the existing links in Project A break because the relative path will change?  Will they all have to be re-mapped?
            If this is so, does anyone have a workaround?
            Thank you in advance for your assistance.
            • 3. Re: Can I create a Merged Help out of two existing Projects?
              If the calls are URLs, then yes they will need to be remapped. However, it will be a case of removing the first part of the URL that is common to all the URLs and then adding a new part that will be common.
              I wonder if your developer can do that with a mass find and replace it might not be too painful.
              The only other option is to import into the first project all the topics that are in the second project, when they will then be broken.
              @petergrainge
