3 Replies Latest reply on Jan 26, 2016 1:09 PM by Schmaltzkopf
    Why does GREP expression need two back-slashes?
    Schmaltzkopf Level 1
      Hi, there.
      Curious question:
      I have the following code:
         psYSbody.nestedGrepStyles.add({
              appliedCharacterStyle: csYSimporedPsukimMekor,
              grepExpression: "\\(.+?\\)"});
      Why does this only work if I have double-backslashes before "()" and "[]"?
      If I only have a single backslash it will totally ignore the backslash.
      Anyone could explain this quirk?
        • 1. Re: Why does GREP expression need two back-slashes?
          Trevorׅ Adobe Community Professional
          Hi
          The "/" character is an escape character. For example if you want to alert "the "big" cat" with the word cat in quotes one way of doing it is alert("the \"big\" cat");
          Because you are providing a string you need to escape the escape
          Try the following 2 examples
          alert("\(") // => (
          alert("\\(") // => \(
          What you want is the second example as the "correct" grep is \( and not (
          Got it?
          Trevor
          • 2. Re: Why does GREP expression need two back-slashes?
            Marc Autret Level 4
            Another way to explain the double-escape trick is to consider those two distinct levels:
            1. At the GREP (or regular expression) level, parentheses ( and ) are special symbols that control capturing groups.
            So if you want to capture a left parenthesis as itself you need to use an escape sequence.
            In GREP, the escape character is \ (backslash) so that the full escape sequence is \( (backslash + parenthesis.)
            2. At the JavaScript level (which is the language you are using to send the above GREP command), the backslash \ is a special symbol when involved in a literal string. Indeed, that symbol is used to form escape sequences!
            So if you want to provide the backslash as itself in a literal string, you need the following escape sequence, "\\" (backslash + backslash), which in fact represents a single backslash character.
            Finally, in order to encode in JavaScript the full GREP pattern \( —that is, a backslash and a left parenthesis—you'll have to use the literal string "\\(".
            [The reasoning is the same for square brackets.]
            Hope that helps.
            Marc
            • 3. Re: Why does GREP expression need two back-slashes?
              Thank you Trevor.
              I'm used to the UI GREP codes, so I appreciate your short and sweet explanation that JS strings are different
