2 Replies Latest reply on Jan 30, 2009 10:17 PM by John Hall
    Advanced Data Grid Sorting / Grouping Collection
    AnakinJay
      Ok, basically here's the issue..
      I have an advanced data grid with a tree view. It goes two levels deep
      so:
      Report Type
      |-------------------- Company
      |--------------------------------------- Report 1
      |--------------------------------------- Report 2
      |--------------------------------------- Report 3
      |-------------------- Company 2
      Report Type 2
      etc..
      Report and Company are Nodes (folders) and are being sorted alphabetically by default.
      The individual reports (Report 1,2,3, etc..) are not being sorted in any way that I can figure out. I need to sort them by date, but no matter what I've tried I can't get it to work.
      I tried a SortCompareFunction on the advancedDataGridColumn that displays each report, and it works *IF* I click the header... but if I dispatch the header_release event via AS3, nothing happens.
      I even set up a test:
      dg.addEventListener(AdvancedDataGridEvent.HEADER_RELEASE,heard);
      dg.dispatchEvent(
      new AdvancedDataGridEvent
      false,
      true,
      0, // The zero-based index of the column to sort in the DataGrid object's columns array.
      null,
      0,
      null,
      null,
      0
      function heard(e:Event) {
      trace("I HEAR IT!");
      trace(e.type);
      I set that up on a button so I can dispatch the event with a click. Every time I click the button, the header release event listener goes off, but the actual advanceddatagrid remains unchanged until I actually click on it's header..
      Any help would be *GREATLY* appreciated... I've been stuck on this problem for two days now :(
        • 1. Re: Advanced Data Grid Sorting / Grouping Collection
          Level 7
          "AnakinJay" <webforumsuser@macromedia.com> wrote in message
          news:glvh5b$4v1$1@forums.macromedia.com...
          > so:
          > Report Type
          > Report Type 2
          > etc..
          > by
          > default.
          > way
          > I've
          > each
          > dg.dispatchEvent(
          > false,
          > true,
          > columns array.
          > null,
          > 0,
          > null,
          > null,
          > 0
          > trace(e.type);
          > the
          > header..
          > for
          > two days now :(
          Check the compareFunctions here
          http://flexdiary.blogspot.com/2008/09/groupingcollection-example-featuring.html
          • 2. Re: Advanced Data Grid Sorting / Grouping Collection
            John Hall Level 4
            Been down this road. However, I put in a lot more than 2 days :-) Very frustrating. The bottom line is I do not know the PROPER way to do it but assuming I understand the problem, here's how I approached it that finally worked.
            It looks like your grouping collection is going its job if the first two levels are sorted properly. And if your situation is like mine, I could get the third level to sort if I added an additional group field but then I had a superfluous folder that repeated the leaf node. All I wanted was the terminal leaf so I didn't want to add the additional folder.
            Anyway, what I finally go to work, though I'd love to hear if you find a efficient solution, is the following.
            I created the grouping collection using the first two grouping fields for the first two levels. That gave me my grouping collection which I then fed into my ADG's hosting component.
            There instead of using the groupingCollection itself as a dataprovider, I used it as the source of a HierarchicalCollectionView. In my case, with treeGC being the grouping collection:
            <mx:HierarchicalCollectionView id="treeDP" source="{treeGC}"/>
            Then I used the treeDP as the dataProvider for the ADG. However, I still had the issue you had where the final leaf wasn't sorting properly but since it was now a hierarchicalCollectionView, the grouping was preserved when I sorted the final level with something along the following lines whenever I had to refresh the data:
